Differences
Both sides previous revision Previous revision | Next revision Both sides next revision | ||
hepsim:usage_detectors [2017/03/07 04:10] hepsim17 |
hepsim:usage_detectors [2017/03/16 00:30] hepsim17 |
Line 25: | Line 25: | ||
- | Full simulations use SLIC software. | + | Full simulations use the SLIC software. |
- | The geometry files with full detector descriptions are [[http:// | + | |
Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as |
