Differences
hepsim:usage_download [2017/02/07 22:00] hepsim17 [Downloading files after detector simulation] |
hepsim:usage_download [2017/04/13 02:59] hepsim17 |
Line 3: | Line 3: | ||
Line 12: | Line 12: | ||
The compact ProMC files optimized for web streaming, together with the http protocol optimized | The compact ProMC files optimized for web streaming, together with the http protocol optimized | ||
to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems. | to handle many (relatively small) files, is one of the distinct features of HepSim compared to other production systems. | ||
Simulated data after fast and full detector simulations are kept in ROOT and LCIO formats. | Simulated data after fast and full detector simulations are kept in ROOT and LCIO formats. | ||
Line 104: | Line 102: | ||
All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers. | All entries are self-explanatory. Varint units - values used to multiply energy (momenta) to convert to variable-byte integers. | ||
- | The " | + | The " |
See the [[http:// | See the [[http:// | ||
Line 111: | Line 109: | ||
- | hs-info http:// | + | hs-info http:// |
Line 213: | Line 211: | ||
If you are interested in a specific reconstruction tag, use " | If you are interested in a specific reconstruction tag, use " | ||
Example: | Example: | ||
hs-find pythia%rfast001 | hs-find pythia%rfast001 | ||
Line 277: | Line 276: | ||
- | [URL] [OUTPUT_DIR] [Nr of threads (optional)] [Nr of files (optional)] [pattern (optional)]. | + | hs-get |
where [URL] is either info URL, [Download URL], or the dataset name. | where [URL] is either info URL, [Download URL], or the dataset name. |
