Differences
hepsim:usage_fast [2017/02/07 02:38] hepsim17 |
hepsim:usage_fast [2017/03/19 19:46] hepsim17 |
Line 1: | Line 1: | ||
{{indexmenu_n> | {{indexmenu_n> | ||
- | [[hepsim:|<< back to HepSim manual]] | + | [[: |
- | ====== Fast detector simulation | + | ====== Fast simulations |
====== Downloading ROOT files ====== | ====== Downloading ROOT files ====== | ||
- | Files after fast detector simulations are created using [[http:// | + | Files after fast detector simulations are created using [[https:// |
- | Assuming that you have installed either** hs-tools** or **Jas4pp** programs, you can download | + | fast simulations using the [[http:// |
- | Here how you can find all samples | + | |
- | for a give tag, say rfast004, use this command: | + | |
- | hs-find tev14_mg5%rfast004 | + | hs-find tev14_mg5%rfast100 |
- | which searches for all samples with the dataset name " | + | which searches for all samples with the dataset name " |
- | Then download a selected sample as: | + | |
- | hs-get tev14_mg5_nlo_httbar%rfast004 | + | hs-get tev14_mg5_nlo_httbar%rfast100 |
- | The description of the detector tags is given in [[community:hepsim: | + | The description of the detector tags is given in [[hepsim: |
+ | ====== Analyzing ROOT files ====== | ||
+ | Read the [[https:// | ||
- | Read the [[https:// | + | Read the section |
