Differences
hepsim:usage_full [2017/02/07 22:07] hepsim17 [Visualizing geometry using ROOT] |
hepsim:usage_full [2017/03/19 19:37] hepsim17 |
Line 3: | Line 3: | ||
- | ====== Full detector | + | ====== Full simulations |
Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and |
