Differences
Both sides previous revision Previous revision | Next revision Both sides next revision | ||
hepsim:usage_full [2017/03/19 19:37] hepsim17 |
Line 3: | Line 3: | ||
Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and | Currently, the Geant4-based detector simulation can be done using the SLIC software. You will need to convert ProMC files to LCIO files and |
