Differences
hepsim:usage_full [2017/03/19 19:37] hepsim17 |
hepsim:usage_full [2017/04/03 01:00] hepsim17 [Using C++/ROOT with LCIO] |
Line 114: | Line 114: | ||
It will compile " | It will compile " | ||
+ | Your program to read SLCIO files can look as this: | ||
+ | <code cpp> | ||
+ | string input=" | ||
+ | LCReader* lcReader = LCFactory:: | ||
+ | lcReader-> | ||
+ | LCEvent* | ||
+ | int nEvents=0; | ||
+ | while( (evt = lcReader-> | ||
+ | if (nEvents==0) UTIL:: | ||
+ | cout << " | ||
+ | // print stored EVGEN parameters | ||
+ | int nFloatParameters = params.getFloatKeys( floatKeys ).size() ; | ||
+ | FloatVec floatVec ; | ||
+ | params.getFloatVals( | ||
+ | int nFloat | ||
+ | cout << " parameter " << floatKeys[i] << " [float]: " ; | ||
+ | for(int j=0; j< nFloat ; j++ ){ | ||
+ | cout << floatVec[j] << ", " ; | ||
+ | cout << endl ; | ||
+ | // extract PFA objects | ||
+ | IMPL:: | ||
+ | int nPFO = col-> | ||
+ | for(int i=0 ; i<nPFO ; ++i){ | ||
+ | EVENT:: | ||
+ | double px = mcp-> | ||
+ | double py = mcp-> | ||
+ | double pz = mcp-> | ||
+ | // look at tracks | ||
+ | IMPL:: | ||
+ | int nTRK = col3-> | ||
+ | for(int i=0 ; i<nTRK ; ++i){ | ||
+ | EVENT:: | ||
+ | lcReader-> | ||
+ | This code example shows how to print float parameters from the EVGEN level (copied from the input ProMC). | ||
+ | Here is the example of all parameters (float, integers, strings): | ||
+ | <code cpp> | ||
+ | Note that SLCIO files have two records representing truth level MC: MCParticle and MCInfo. MCInfo includes information on generated events. | ||
+ | See the example how this record was created in [[https:// | ||
