Both sides previous revision
Previous revision
Next revision
Previous revision
Next revision
Both sides next revision
start [2017/02/07 02:52] hepsim17 |
start [2022/03/17 20:18] hepsim17 [About HepSim] |
====== HepSim manual ====== | ====== HepSim manual ====== |
| ===== About HepSim ===== |
| [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] is a public repository with Monte Carlo simulated events for particle-collision experiments. |
| The [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]] was started at ANL during the US long-term planning study of the American Physical Society’s Division of Particles and Fields (Snowmass 2013). |
| It contains predictions from leading-order (LO) parton shower models, next-to-leading order (NLO) and NLO with matched parton showers. |
| It also includes Monte Carlo events after fast ("parametric") and full (Geant4) detector simulations and event reconstruction. |
| HepSim contains event samples for physics and detector-performance studies |
| for High-Luminosity LHC (HL-LHC), International Linear Collider (ILC), Very Large Hadron Collider (VLHC), Future Circular Collider (FCC-ee and FCC-hh), |
| Compact Linear Collider (CLIC), Circular Electron-Positron Collider (CEPC), Electron-Ion Collider (EIC) and other future particle colliders. |
| HepSim Monte Carlo samples are registered by the U.S. Department of Energy |
| Office of Scientific and Technical Information, [[https://www.osti.gov/elink/ | OSTI.GOV]]. |
| Each event sample is assigned a DOI (Digital Object Identifier) number as listed on the [[https://www.osti.gov/search/semantic:ANL-HEPSIM|ANL-HEPSIM OSTI.GOV]] page. |
| The assigned DOI numbers are also indicated on the HepSim information panel for datasets. |
| HepSim was designed following |
| the guidelines and principles of [[http://www.energy.gov/sites/prod/files/2014/08/f18/DOE_Public_Access%20Plan_FINAL.pdf|DOE Public Access Plan]] |
| for unclassified and otherwise unrestricted scientific data in digital formats. |
[[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] is a public repository with Monte Carlo simulated events for high-energy physics (HEP) experiments. | |
The [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim repository]] was started at ANL during the US long-term planning study of the American Physical Society’s Division of Particles and Fields (Snowmass 2013) with the goal to create references to truth-level MC records for current and future experiments. | |
====== For HepSim users ====== | ====== For HepSim users ====== |
* [[hepsim:quick|Quick start with HepSim]] | * [[hepsim:quick|Quick start with HepSim]] |
* [[hepsim:usage_download| How to find, view and download data]] | * [[hepsim:usage_download| How to find, view and download data]] |
* [[hepsim:usage_truth| How to perform data analysis using truth-level files]] | * [[hepsim:usage_truth| Making plots using EVGEN (truth-level) files]] |
* [[hepsim:usage_analysis| HepSim analysis tutorial]] | * [[hepsim:usage_analysis| HepSim analysis tutorial]] |
* [[hepsim:usage_fast| How to analyse fast simulations]] | * [[hepsim:usage_fast| How to analyse fast simulations]] |
* [[hepsim:usage_detectors| Detector descriptions and reconstructed tags]] | * [[hepsim:usage_detectors| Detector descriptions and reconstructed tags]] |
| <note tip>See also: {{:hepsim_tour.pdf|"A tour of HepSim from user's perspective" by David Blyth}} |
| ([[https://docs.google.com/presentation/d/1GT8Q_VTtW8ekeLWxSrvta32p6nbc4uIX_1NzU2DZ-G0/edit?usp=sharing|or in pptx]]) |
| </note> |
====== Physics and detector studies ====== | ====== Physics and detector studies ====== |
{{:hepsim:bghep1.png?1600x20|HepSim manual:Physics and detector studies}} | {{:hepsim:bghep1.png?1600x20|HepSim manual:Physics and detector studies}} |
Here are several links to extending this Wiki for particular detector-performance topics: | Here are several links for extending this Wiki for particular detector-performance topics: |
{{:hepsim:bghep1.png?1600x20|HepSim manual:For developers}} | {{:hepsim:bghep1.png?1600x20|HepSim manual:For developers}} |
If you plan to contribute to HepSim (Monte Carlo events, data storage etc), start from here: | If you plan to contribute to HepSim (Monte Carlo events, data storage etc), read this: |
* [[hepsim:dev_truth | Creating truth-level samples]] | * [[hepsim:dev_truth | Creating truth-level samples]] |
If you use HepSim event samples, Python/Jython analysis scripts and output XML files in your research, talks or | If you use HepSim event samples, Python/Jython analysis scripts and output XML files in your research, talks or |
publications, please cite this project as: | publications, please cite this project as: |
S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments//. Advances in High Energy Physics, vol. 2015, ID136093, 2015. [[http://arxiv.org/abs/1403.1886 | arXiv:1403.1886]] and [[http://www.hindawi.com/journals/ahep/2015/136093/|link]]. | S.V. Chekanov. //HepSim: a repository with predictions for high-energy physics experiments//. Advances in High Energy Physics, vol. 2015, ID136093, 2015. [[http://arxiv.org/abs/1403.1886 | arXiv:1403.1886]] and [[http://www.hindawi.com/journals/ahep/2015/136093/|link]]. |
