Differences
fcs:cepc:2017 [2017/09/18 21:26] hepsim17 |
fcs:cepc:2017 [2017/09/21 14:09] hepsim17 [Some physics plots] |
Line 32: | Line 32: | ||
- | The calculated values are: | ||
- | # X | ||
- | 10.146249520505538 7.233707688030497E-4 5.704907825633882 5.704907825633882 8.502371007125989E-6 8.502371007125989E-6 | ||
- | 29.97624545765604 2.4885582068389435E-4 5.78713865684815 5.78713865684815 2.7299775405151286E-6 2.7299775405151286E-6 | ||
- | 49.954003533114985 1.4832996719960168E-4 5.769439544642645 5.769439544642645 1.5468566955835806E-6 1.5468566955835806E-6 | ||
- | 69.93649191232116 1.0747555580737206E-4 5.73788457385378 5.73788457385378 1.207919858957492E-6 1.207919858957492E-6 | ||
- | 89.98736169597974 8.74971031060202E-5 5.7789623998936674 5.7789623998936674 9.720552302933245E-7 9.720552302933245E-7 | ||
- | 109.9722327265809 7.276974424666559E-5 5.785881825564851 5.785881825564851 8.011527768175124E-7 8.011527768175124E-7 | ||
- | 130.00571018130168 6.643313435056274E-5 5.738190270370251 5.738190270370251 7.232826222201539E-7 7.232826222201539E-7 | ||
Line 67: | Line 54: | ||
- | Here the data for the latter plot: | + | Here is the tracking resolution |
- | # title=track resolution | + | |
- | # X | + | |
- | 10.32433631523229 4.867902978029176E-4 5.649317349227959 5.649317349227959 9.095115287399043E-6 9.095115287399043E-6 | + | |
- | 30.037640678369865 1.663426885561398E-4 5.749498917792368 5.749498917792368 2.5309641727660808E-6 2.5309641727660808E-6 | + | |
- | 49.90826061858357 1.0363260377582206E-4 5.772779435179446 5.772779435179446 1.6407434405702103E-6 1.6407434405702103E-6 | + | |
- | 70.01468589846364 7.435683114678843E-5 5.780868774405953 5.780868774405953 1.4610908375521488E-6 1.4610908375521488E-6 | + | |
- | 90.0885946572771 6.167486360935256E-5 5.826907071697395 5.826907071697395 1.5285139237718334E-6 1.5285139237718334E-6 | + | |
- | 109.9687018781744 5.009402782415849E-5 5.7704065390138695 5.7704065390138695 1.0579095942002432E-6 1.0579095942002432E-6 | + | |
- | 130.05120795630376 4.777645240305135E-5 5.770596760482526 5.770596760482526 1.126358108856388E-6 1.126358108856388E-6 | + | |
+ | The data file is {{ : | ||
+ | You can read jdat file in PyROOT using this simple macro {{ : | ||
+ | ====== Tracking in Barrel and Endcap ====== | ||
+ | ===== pT resolution ===== | ||
+ | As before, this was done using B=3 and R=1.8m tracker and [[http:// | ||
+ | Data files are {{: | ||
+ | The results were created with the scripts {{: | ||
+ | ===== d0 and z0 resolution ===== | ||
+ | The files with data are: | ||
+ | ===== Some physics plots ===== | ||
+ | Here are a few plots illustrating physics performances. The figures have been done using fully identified muons and electrons (PandoraPFO). The following samples (tag rfull102) have been used: | ||
+ | * [[http:// | ||
+ | You can get the data (for Z0+Higgs-> | ||
+ | <code bash> | ||
+ | bash # | ||
+ | wget http:// | ||
+ | source hs-toolkit/ | ||
+ | hs-get gev250ee_pythia8_zhiggs_nunumumu | ||
+ | hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag | ||
- | </hidden> | + | |
+ | See [[http:// | ||
+ | Now you can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in [[hepsim: | ||
+ | Here are a few plots that show the performance using [[http:// | ||
+ | Here is the plot for [[http:// | ||
