Differences
fcs:cepc:2017 [2017/09/19 21:20] hepsim17 [Tracking in Barrel and Endcap] |
fcs:cepc:2017 [2017/09/21 14:09] hepsim17 [Some physics plots] |
Line 32: | Line 32: | ||
- | The calculated values are: | ||
- | # X | ||
- | 10.146249520505538 7.233707688030497E-4 5.704907825633882 5.704907825633882 8.502371007125989E-6 8.502371007125989E-6 | ||
- | 29.97624545765604 2.4885582068389435E-4 5.78713865684815 5.78713865684815 2.7299775405151286E-6 2.7299775405151286E-6 | ||
- | 49.954003533114985 1.4832996719960168E-4 5.769439544642645 5.769439544642645 1.5468566955835806E-6 1.5468566955835806E-6 | ||
- | 69.93649191232116 1.0747555580737206E-4 5.73788457385378 5.73788457385378 1.207919858957492E-6 1.207919858957492E-6 | ||
- | 89.98736169597974 8.74971031060202E-5 5.7789623998936674 5.7789623998936674 9.720552302933245E-7 9.720552302933245E-7 | ||
- | 109.9722327265809 7.276974424666559E-5 5.785881825564851 5.785881825564851 8.011527768175124E-7 8.011527768175124E-7 | ||
- | 130.00571018130168 6.643313435056274E-5 5.738190270370251 5.738190270370251 7.232826222201539E-7 7.232826222201539E-7 | ||
Line 67: | Line 54: | ||
+ | Here is the tracking resolution for 1/pt: | ||
+ | The data file is {{ : | ||
+ | You can read jdat file in PyROOT using this simple macro {{ : | ||
====== Tracking in Barrel and Endcap ====== | ====== Tracking in Barrel and Endcap ====== | ||
+ | ===== pT resolution ===== | ||
As before, this was done using B=3 and R=1.8m tracker and [[http:// | As before, this was done using B=3 and R=1.8m tracker and [[http:// | ||
Line 82: | Line 78: | ||
The results were created with the scripts {{: | The results were created with the scripts {{: | ||
+ | ===== d0 and z0 resolution ===== | ||
+ | The files with data are: | ||
+ | ===== Some physics plots ===== | ||
+ | Here are a few plots illustrating physics performances. The figures have been done using fully identified muons and electrons (PandoraPFO). The following samples (tag rfull102) have been used: | ||
+ | * [[http:// | ||
+ | You can get the data (for Z0+Higgs-> | ||
+ | <code bash> | ||
+ | bash # | ||
+ | wget http:// | ||
+ | source hs-toolkit/ | ||
+ | hs-get gev250ee_pythia8_zhiggs_nunumumu | ||
+ | hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag | ||
+ | See [[http:// | ||
+ | [[hepsim: | ||
+ | Here are a few plots that show the performance using [[http:// | ||
+ | Here is the plot for [[http:// | ||
