Both sides previous revision
Previous revision
Next revision
Previous revision
Last revision
Both sides next revision
fcs:cepc:2017 [2017/09/20 18:46] hepsim17 |
fcs:cepc:2017 [2017/09/21 14:09] hepsim17 [Some physics plots] |
Here are a few plots illustrating physics performances. The figures have been done using fully identified muons and electrons (PandoraPFO). The following samples (tag rfull102) have been used: | Here are a few plots illustrating physics performances. The figures have been done using fully identified muons and electrons (PandoraPFO). The following samples (tag rfull102) have been used: |
* [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]] | * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]] - Z->mu+mu- |
* [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] | * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes) |
* [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] | * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e- |
| * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=294|gev250ee_pythia8_zhiggs_nunumumu]] - Z0+Higgs-> nunu+mu+mu- |
| * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=295|gev250ee_pythia8_zhiggs_nunugg]] - Z0+Higgs-> nunu+gg |
| You can get the data (for Z0+Higgs-> nunu+mu+mu-, for example), as: |
| <code bash> |
| bash # set bash if you haven't done this before |
| wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; |
| source hs-toolkit/setup.sh |
| hs-get gev250ee_pythia8_zhiggs_nunumumu # download ProMC (truth) files |
| hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag |
| </code> |
| See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]]. You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in |
| [[hepsim:dev_full|this section]]. |
| Here are a few plots that show the performance using [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]]: |
{{:fcs:cepc:zpeak_mumu_fit.png?400|}} | {{:fcs:cepc:zpeak_mumu_fit.png?400|}} |
| Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes) |
{{:fcs:cepc:higgs_mumu_fit.png?400|}} | {{:fcs:cepc:higgs_mumu_fit.png?400|}} |
| Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e- |
{{:fcs:cepc:zpeak_ee_fit.png?400|}} | {{:fcs:cepc:zpeak_ee_fit.png?400|}} |
