Both sides previous revision
Previous revision
Next revision
Previous revision
Last revision
Both sides next revision
fcs:cepc:2017 [2017/09/21 12:43] hepsim17 |
fcs:cepc:2017 [2017/09/21 14:09] hepsim17 [Some physics plots] |
wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; | wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; |
source hs-toolkit/setup.sh | source hs-toolkit/setup.sh |
hs-get gev250ee_pythia8_zhiggs_nunumumu | hs-get gev250ee_pythia8_zhiggs_nunumumu # download ProMC (truth) files |
| hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag |
</code> | </code> |
See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]. You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters: | |
<code bash> | |
wget http://atlaswww.hep.anl.gov/hepsim/soft/promc2other.tgz | |
tar -zvxf promc2other.tgz | |
cd promc2other | |
</code> | |
| See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]]. You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in |
| [[hepsim:dev_full|this section]]. |
| Here are a few plots that show the performance using [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]]: |
{{:fcs:cepc:zpeak_mumu_fit.png?400|}} | {{:fcs:cepc:zpeak_mumu_fit.png?400|}} |
| Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes) |
{{:fcs:cepc:higgs_mumu_fit.png?400|}} | {{:fcs:cepc:higgs_mumu_fit.png?400|}} |
| Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e- |
{{:fcs:cepc:zpeak_ee_fit.png?400|}} | {{:fcs:cepc:zpeak_ee_fit.png?400|}} |
