Differences
Link to this comparison view
Next revision
Previous revision
fcs:cepc:2017 [2017/09/21 12:43]
hepsim17 [Some physics plots]
fcs:cepc:2017 [2017/09/21 14:09]
Line 107: Line 107:
 You can get the data (for Z0+Higgs-> nunu+mu+mu-, for example), as: You can get the data (for Z0+Higgs-> nunu+mu+mu-, for example), as:
-<code>+<code bash>
 bash   #  set bash if you haven't done this before  bash   #  set bash if you haven't done this before
 wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz;
 source hs-toolkit/setup.sh source hs-toolkit/setup.sh
-hs-get gev250ee_pythia8_zhiggs_nunumumu+hs-get gev250ee_pythia8_zhiggs_nunumumu          # download ProMC (truth) files
 +hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag
 </code> </code>
-See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]]. You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters:
-<code bash>
-wget http://atlaswww.hep.anl.gov/hepsim/soft/promc2other.tgz
-tar -zvxf promc2other.tgz
-cd promc2other
-</code>
 +See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]].
 +Now you  can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in [[hepsim:dev_full|ProMC to LCIO/STDHEP section]].
 +Here are a few plots that show the performance using [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]]:
 {{:fcs:cepc:zpeak_mumu_fit.png?400|}} {{:fcs:cepc:zpeak_mumu_fit.png?400|}}
 +Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes)
 {{:fcs:cepc:higgs_mumu_fit.png?400|}} {{:fcs:cepc:higgs_mumu_fit.png?400|}}
 +Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e-
 {{:fcs:cepc:zpeak_ee_fit.png?400|}} {{:fcs:cepc:zpeak_ee_fit.png?400|}}
