Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
fcs:cepc:2017 [2017/09/21 13:02] hepsim17 [Some physics plots] |
fcs:cepc:2017 [2017/09/21 14:09] hepsim17 [Some physics plots] |
See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]]. You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters: | See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]]. |
<code bash> | |
wget http://atlaswww.hep.anl.gov/hepsim/soft/promc_convert.tgz | Now you can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in [[hepsim:dev_full|ProMC to LCIO/STDHEP section]]. |
tar -zvxf promc_convert.tgz | |
cd promc_convert | |
promc2lcio.sh input.promc output.slcio # convert to SLCIO | |
promc2stdhep.sh input.promc output.stdhep # convert to STDHEP | |
</code> | |
Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e- | Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e- |
{{:fcs:cepc:zpeak_ee_fit.png?400|}} | {{:fcs:cepc:zpeak_ee_fit.png?400|}} |
