Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
fcs:fcchh [2017/04/16 13:44]
hepsim17
fcs:fcchh [2017/04/16 13:45]
hepsim17
Line 8: Line 8:
 **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL) **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL)
-The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" detector [[https://arxiv.org/abs/1612.07291|ref]], called "SiFCC". Unlike the "FCChh-reference detector" developed at CERN, the SiFCC detector:+The current goal of the studies is to understand physics requirements and design options using the [[https://arxiv.org/abs/1612.07291|FCC-performance detector]], called "SiFCC". Unlike the "FCChh-reference detector" developed at CERN, the SiFCC detector:
   * derived from the SiD concept (or CLIC)   * derived from the SiD concept (or CLIC)
