Differences
hepsim:dev_fast [2017/03/19 19:56] hepsim17 |
hepsim:dev_fast [2017/08/30 12:41] hepsim17 |
Line 1: | Line 1: | ||
Line 15: | Line 15: | ||
echo $PROMC $ROOTSYS | echo $PROMC $ROOTSYS | ||
- | This should point to the installation paths of ProMC and ROOT. The detectors configurations for Delphes together with appropriate Delphes package are posted to [[http:// | + | This should point to the installation paths of ProMC and ROOT. The detectors configurations for Delphes together with appropriate Delphes package are posted to [[http:// |
Copy the ZIP file with Delphes card and Delphes package and compile it. | Copy the ZIP file with Delphes card and Delphes package and compile it. | ||
Line 27: | Line 27: | ||
cd $det | cd $det | ||
tar --strip-components=1 -zvxf Delphes*.tar.gz # untar in the current directory | tar --strip-components=1 -zvxf Delphes*.tar.gz # untar in the current directory | ||
- | ./ | + | ./configure; make |
- | make | + | |
- | + | The last command should create the binary file " | |
- | Now you can process a ProMC file: | + | |
- | http:// | + | wget http:// |
This commands creates a ROOT file with fast simulations. | This commands creates a ROOT file with fast simulations. | ||
- | Detector configuration files [detector].zip include the Delphes | + | Detector configuration files [detector].zip include the Delphes |
- | and the input control card " | + | and the input control card " |
Line 65: | Line 61: | ||
- | One can also run Delphes in automated mode, without the above scripts. You need to use " | + | One can also run Delphes in an automated mode, without the above scripts. You need to use " |
- | hs-exec DelphesProMC | + | hs-exec DelphesProMC |
where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | ||
Line 73: | Line 69: | ||
Here is a small example: | Here is a small example: | ||
- | which processes 5 files from [[http://mc.hep.anl.gov/asc/hepsim/events/ | + | which processes 5 files from [[http://atlaswww.hep.anl.gov/ |
