Differences
hepsim:dev_fast [2017/03/19 20:04] hepsim17 |
hepsim:dev_fast [2017/03/19 20:11] hepsim17 [Creating Delphes files] |
Line 32: | Line 32: | ||
- | http:// | + | wget http:// |
This commands creates a ROOT file with fast simulations. | This commands creates a ROOT file with fast simulations. | ||
Line 61: | Line 61: | ||
- | One can also run Delphes in automated mode, without the above scripts. You need to use " | + | One can also run Delphes in an automated mode, without the above scripts. You need to use " |
- | hs-exec DelphesProMC | + | hs-exec DelphesProMC |
where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | ||
Line 69: | Line 69: | ||
Here is a small example: | Here is a small example: | ||
- | which processes 5 files from [[http://mc.hep.anl.gov/asc/hepsim/events/ | + | which processes 5 files from [[http://atlaswww.hep.anl.gov/ |
