Differences
hepsim:dev_fast [2017/03/19 20:04] hepsim17 |
hepsim:dev_fast [2018/04/27 16:35] hepsim17 |
Line 1: | Line 1: | ||
- | {{indexmenu_n> | + | {{indexmenu_n> |
Line 8: | Line 8: | ||
Fast simulations in the HepSim are posted under the [[http:// | Fast simulations in the HepSim are posted under the [[http:// | ||
+ | Generally, you do not need to install Delphes to run fast simulations. You can run fast simulations using the HepSim singularity container. This topic is described in [[hepsim: | ||
+ | Below is the description how to use Delphes if you do not want to use the HepSim docker container. | ||
===== Creating Delphes files ===== | ===== Creating Delphes files ===== | ||
Line 32: | Line 36: | ||
- | http:// | + | wget http:// |
This commands creates a ROOT file with fast simulations. | This commands creates a ROOT file with fast simulations. | ||
Line 61: | Line 65: | ||
- | One can also run Delphes in automated mode, without the above scripts. You need to use " | + | One can also run Delphes in an automated mode, without the above scripts. You need to use " |
- | hs-exec DelphesProMC | + | hs-exec DelphesProMC |
where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | where [URL] is HepSim location of files and [Nfiles] is the number of files for processing. | ||
Line 69: | Line 73: | ||
Here is a small example: | Here is a small example: | ||
- | which processes 5 files from [[http://mc.hep.anl.gov/asc/hepsim/events/ | + | which processes 5 files from [[http://atlaswww.hep.anl.gov/ |
Line 175: | Line 179: | ||
+ | <note important> | ||
