Differences
hepsim:dev_fast [2017/03/19 20:10] hepsim17 |
hepsim:dev_fast [2017/08/30 12:42] hepsim17 |
Line 1: | Line 1: | ||
Line 62: | Line 62: | ||
One can also run Delphes in an automated mode, without the above scripts. You need to use " | One can also run Delphes in an automated mode, without the above scripts. You need to use " | ||
hs-exec DelphesProMC card.tcl output.root [URL] [Nfiles] | hs-exec DelphesProMC card.tcl output.root [URL] [Nfiles] | ||
Line 69: | Line 69: | ||
Here is a small example: | Here is a small example: | ||
hs-exec DelphesProMC card.tcl output.root http:// | hs-exec DelphesProMC card.tcl output.root http:// | ||
