Differences
hepsim:dev_fast [2017/03/19 20:10] hepsim17 |
hepsim:dev_fast [2017/09/24 22:33] hepsim17 |
Line 1: | Line 1: | ||
Line 8: | Line 8: | ||
Fast simulations in the HepSim are posted under the [[http:// | Fast simulations in the HepSim are posted under the [[http:// | ||
+ | Generally, you do not need to install Delphes to run fast simulations. You can run fast simulations using the HepSim singularity container. This topic is described in [[hepsim: | ||
+ | Below is the description how to use Delphes if you do not want to use the HepSim docker container. | ||
===== Creating Delphes files ===== | ===== Creating Delphes files ===== | ||
Line 62: | Line 66: | ||
One can also run Delphes in an automated mode, without the above scripts. You need to use " | One can also run Delphes in an automated mode, without the above scripts. You need to use " | ||
hs-exec DelphesProMC card.tcl output.root [URL] [Nfiles] | hs-exec DelphesProMC card.tcl output.root [URL] [Nfiles] | ||
Line 69: | Line 73: | ||
Here is a small example: | Here is a small example: | ||
hs-exec DelphesProMC card.tcl output.root http:// | hs-exec DelphesProMC card.tcl output.root http:// | ||
