Differences
hepsim:dev_fast [2017/03/19 20:11] hepsim17 [Creating Delphes files] |
hepsim:dev_fast [2017/09/24 22:33] hepsim17 |
Line 1: | Line 1: | ||
Line 8: | Line 8: | ||
Fast simulations in the HepSim are posted under the [[http:// | Fast simulations in the HepSim are posted under the [[http:// | ||
+ | Generally, you do not need to install Delphes to run fast simulations. You can run fast simulations using the HepSim singularity container. This topic is described in [[hepsim: | ||
+ | Below is the description how to use Delphes if you do not want to use the HepSim docker container. | ||
===== Creating Delphes files ===== | ===== Creating Delphes files ===== |
