Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hepsim:dev_fast [2017/08/30 12:41]
hepsim17
hepsim:dev_fast [2017/09/24 22:33]
hepsim17
Line 1: Line 1:
- {{indexmenu_n>11}}+ {{indexmenu_n>12}}
Line 8: Line 8:
 Fast simulations in the HepSim are posted under the [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast|rfast link]]. The detectors configurations are posted to [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|this link]]. Fast simulations in the HepSim are posted under the [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast|rfast link]]. The detectors configurations are posted to [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|this link]].
 +Generally, you do not need to install Delphes to run fast simulations. You can run fast simulations using the HepSim singularity container. This topic is described in [[hepsim:dev_singularity|HepSim singularity container]] section.
 +Below is the description how to use Delphes if you do not want to use the HepSim docker container.
 ===== Creating Delphes files  ===== ===== Creating Delphes files  =====
