Differences
hepsim:dev_fast [2017/08/30 12:41] hepsim17 |
hepsim:dev_fast [2018/04/27 16:35] hepsim17 |
Line 1: | Line 1: | ||
- | {{indexmenu_n> | + | {{indexmenu_n> |
Line 8: | Line 8: | ||
Fast simulations in the HepSim are posted under the [[http:// | Fast simulations in the HepSim are posted under the [[http:// | ||
+ | Generally, you do not need to install Delphes to run fast simulations. You can run fast simulations using the HepSim singularity container. This topic is described in [[hepsim: | ||
+ | Below is the description how to use Delphes if you do not want to use the HepSim docker container. | ||
===== Creating Delphes files ===== | ===== Creating Delphes files ===== | ||
Line 175: | Line 179: | ||
+ | <note important> | ||
