Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hepsim:dev_fpadsim [2017/09/24 00:10]
hepsim17
hepsim:dev_fpadsim [2017/09/24 02:10]
hepsim17
Line 10: Line 10:
 Many samples posted in HepSim are created with the  package called "fpadsim" (**F**uture **Pa**rticle **D**etector **Sim**ulator"). This package is under constant development.  Many samples posted in HepSim are created with the  package called "fpadsim" (**F**uture **Pa**rticle **D**etector **Sim**ulator"). This package is under constant development.
-The contributed authors of this package since 2015 are: +)
-  * D.Blyth (HEP/ANL) +
-  * J.MacCormick (SLAC) +
-  * W.Armstrong  (PHYS/HEP) +
-  * S.Chekanov (HEP/ANL) +
-  * A.Kotwal (Duke) +
-  * J.Strube (PNNL) +
-  * J.Marshall (U.Cambridge)+
Line 40: Line 32:
 To process truth-level events with FpadSim, you need a few things: To process truth-level events with FpadSim, you need a few things:
-  * Tag file with detector description +  * Tag file with detector description. The concept of tag files is described in Sect.[[hepsim:dev_tags]]. You can find all submitted tag files in [[http://atlaswww.hep.anl.gov/hepsim/recotags.php|tag file catalog]]
-  * Singularity image with pre-built libraries to process the tag file+  * Singularity image with pre-built libraries to process a given tag file
 +The tag files should be processed with the simulation and reconstruction chain described above.
 +This can be done by using [[http://singularity.lbl.gov/|Singularity]] that enables users to have full control of their environment. Install singularity (version 2.3.1 and above) and download the CentOS7 HEPSIM image with the
 +FPadSim software.
 +Here is the download link [[http://atlaswww.hep.anl.gov/hepsim/soft/centos7hepsim.img|centos7hepsim.img]] (>5 GB).
 +The image includes basic CentOS7 environment, and programs such as SLIC, LCSIM, slicPandora, ProMC, Jas4PP and various
 +converters.
 +<code bash>
 +wget http://atlaswww.hep.anl.gov/hepsim/soft/centos7hepsim.img # get the singularity image
 +singularity  exec centos7hepsim.img  bash -l                   # setup fpadsim
 +</code>
 +After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands.
 +Now you can process the tag file:
 +<code bash>
 +wget http://atlaswww.hep.anl.gov/hepsim/soft/rfull102.tgz
 +tar -zvxf rfull102.tgz
 +cd ilcsoft/rfull102/
 +./TEST.sh #  runs simple a test with single particles
 +</code>
 +The final file after pandoraPFA reconstruction with the name *hepsim.slcio" will be created in the same directory.
 +Other files after simulation and track reconstruction steps will be located inside "output" directory.
 +To process other promc files, download the required promc files and edit the file Test.sh
 +More information can be found in Section [[hepsim:dev_singularity|HepSim singularity image]]
 +===== Light version of FPadSim image=====
 +David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs:eic:singularity|singularity image for EIC]]. It is based on Arch Linux, and does not contain the usual Linux environment included inside centos7hepsim image.
 +====== Contributions ======
 +The contributed authors of this package since 2015 are:
 +  * D.Blyth (HEP/ANL)
 +  * J.MacCormick (SLAC)
 +  * W.Armstrong  (PHYS/HEP)
 +  * S.Chekanov (HEP/ANL)
 +  * A.Kotwal (Duke)
 +  * J.Strube (PNNL)
 +  * J.Marshall (U.Cambridge)
  --- //[[[email protected]|Sergei Chekanov]] 2017/04/12 21:58//  --- //[[[email protected]|Sergei Chekanov]] 2017/04/12 21:58//
