Differences
hepsim:dev_fpadsim [2017/09/24 01:52] hepsim17 [Contributions] |
hepsim:dev_fpadsim [2017/09/24 22:52] hepsim17 [Simulations with FPadSim] |
Line 32: | Line 32: | ||
To process truth-level events with FpadSim, you need a few things: | To process truth-level events with FpadSim, you need a few things: | ||
- | * Tag file with detector description. The concept of tag files is described in Sect.[[hepsim: | + | * A tag file with the detector description. The concept of tag files is described in Sect.[[hepsim: |
- | * Singularity | + | * Singularity |
The tag files should be processed with the simulation and reconstruction chain described above. | The tag files should be processed with the simulation and reconstruction chain described above. | ||
- | This can be done by using [[http:// | + | This can be done by using [[http:// |
- | FPadSim software. | + | |
- | Here is the download link [[http:// | + | Here is the download link [[http:// |
- | The image includes basic CentOS7 environment, | + | The image includes basic CentOS7 environment, |
- | converters. | + | |
- | wget http:// | + | wget http:// |
- | singularity | + | singularity |
- | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | + | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. |
- | You can also use the commands such as: | + | |
- | <code bash> | + | |
- | promc2lcio | + | |
- | promc2stdhep # convert ProMC file to STDHEP | + | |
- | and many other. | + | |
Now you can process the tag file: | Now you can process the tag file: | ||
Line 69: | Line 60: | ||
To process other promc files, download the required promc files and edit the file Test.sh | To process other promc files, download the required promc files and edit the file Test.sh | ||
- | ====== Singularity image ====== | + | More information about how to use HepSim container can be found in Section [[hepsim: |
- | The singularity [[http:// | + | ===== Light version of FPadSim |
- | is created using CentOS7 using singularity version 2.3.1. It has the basic linux commands, vim editor and | + | |
- | all the required packages. | + | |
- | Look inside this image as: | + | |
- | sudo singularity shell --contain --writable centos7hepsim.img | + | |
- | and check the directory "/ | + | |
- | Here are a few useful commands: | + | |
- | sudo singularity shell --contain --writable centos7hepsim.img # open to make changes | + | |
- | singularity expand centos7hepsim.img | + | |
- | singularity copy | + | |
- | ===== Light version of image===== | + | |
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: | + | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: |
Line 104: | Line 77: | ||
* A.Kotwal (Duke) | * A.Kotwal (Duke) | ||
* J.Strube (PNNL) | * J.Strube (PNNL) | ||
- | * J.Marshall (U.Cambridge | + | * J.Marshall (U.Cambridge) |
