Differences
hepsim:dev_fpadsim [2017/09/24 01:53] hepsim17 [Light version of image] |
hepsim:dev_fpadsim [2017/09/24 02:10] hepsim17 |
Line 39: | Line 39: | ||
FPadSim software. | FPadSim software. | ||
- | Here is the download link [[http:// | + | Here is the download link [[http:// |
The image includes basic CentOS7 environment, | The image includes basic CentOS7 environment, | ||
converters. | converters. | ||
- | wget http:// | + | wget http:// |
- | singularity | + | singularity |
- | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | + | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. |
- | You can also use the commands such as: | + | |
- | <code bash> | + | |
- | promc2lcio | + | |
- | promc2stdhep # convert ProMC file to STDHEP | + | |
- | and many other. | + | |
Now you can process the tag file: | Now you can process the tag file: | ||
Line 69: | Line 62: | ||
To process other promc files, download the required promc files and edit the file Test.sh | To process other promc files, download the required promc files and edit the file Test.sh | ||
- | ====== Singularity | + | More information can be found in Section [[hepsim: |
- | The singularity [[http:// | + | ===== Light version of FPadSim |
- | is created using CentOS7 using singularity version 2.3.1. It has the basic linux commands, vim editor and | + | |
- | all the required packages. | + | |
- | Look inside this image as: | + | |
- | sudo singularity shell --contain --writable centos7hepsim.img | + | |
- | and check the directory "/ | + | |
- | Here are a few useful commands: | + | |
- | sudo singularity shell --contain --writable centos7hepsim.img # open to make changes | + | |
- | singularity expand centos7hepsim.img | + | |
- | singularity copy | + | |
- | ===== Light version of image===== | + | |
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: | + | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: |
Line 104: | Line 79: | ||
* A.Kotwal (Duke) | * A.Kotwal (Duke) | ||
* J.Strube (PNNL) | * J.Strube (PNNL) | ||
- | * J.Marshall (U.Cambridge | + | * J.Marshall (U.Cambridge) |
