Differences
Both sides previous revision Previous revision | Last revision Both sides next revision | ||
hepsim:dev_fpadsim [2017/09/24 02:10] hepsim17 |
Line 45: | Line 45: | ||
- | singularity | + | singularity |
After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. |
