Differences
hepsim:dev_full [2017/09/21 13:50] hepsim17 |
hepsim:dev_full [2017/09/21 19:18] hepsim17 |
Line 5: | Line 5: | ||
===== Creating LCIO files ===== | ===== Creating LCIO files ===== | ||
- | In many cases, HepSim detector simulations were done using SiD-derived software, such as those used for ILC, CLIC, etc. expeeiments. | + | In many cases, HepSim detector simulations were done using ILCSOFT-derived software, such as those used for ILC, CLIC, etc. experiments. |
+ | To perform Geant4 simulations, | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | tar -zvxf promc_convert.tgz | ||
+ | cd promc_convert | ||
- | To create full simulations, | + | You can convert |
- | [[hepsim:usage_truth# | + | |
- | {{indexmenu_n>13}} | + | <code bash> |
- | [[:|<< back to HepSim manual]] | + | ./ |
- | ===== Simulation with FPadSim ===== | ||
- | In many cases, HepSim detector simulations were done using SiD-derived software. | ||
- | To create full simulations, | ||
- | [[hepsim: | ||
+ | Files in the LCIO or STDHEP formats can be used as input for DD4HEP or SLIC simulation packages. | ||
+ | Many samples of HepSim were created with a dedicated FPadSim package. See [[hepsim: | ||
