Differences
hepsim:dev_full [2017/09/21 13:55] hepsim17 |
hepsim:dev_full [2017/09/21 13:57] hepsim17 [Creating LCIO files] |
Line 5: | Line 5: | ||
===== Creating LCIO files ===== | ===== Creating LCIO files ===== | ||
- | In many cases, HepSim detector simulations were done using SiD-derived software, such as those used for ILC, CLIC, etc. experiments. To perform such simulation, you will need to convert PROMC to SLCIO or STDHEP files. | + | In many cases, HepSim detector simulations were done using ILCSOFT-derived software, such as those used for ILC, CLIC, etc. experiments. |
- | You can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters: | + | To perform Geant4 simulations, |
Line 20: | Line 20: | ||
Files in the LCIO or STDHEP formats can be used as input for DD4HEP or SLIC simulation packages. | Files in the LCIO or STDHEP formats can be used as input for DD4HEP or SLIC simulation packages. | ||
- | Many samples of HepSim were created a dedicated FPadSim package. See [[hepsim: | + | Many samples of HepSim were created |
