Differences
hepsim:dev_hepsim [2019/04/23 01:30] hepsim17 [Using Petrel from Globus] |
hepsim:dev_hepsim [2020/06/26 21:21] hepsim17 |
Line 3: | Line 3: | ||
- | ====== Linking event storages====== | + | ====== Linking event storage |
- | Your files can be published on [[http:// | + | Monte Carlo files from any location |
+ | HepSim | ||
+ | to maintain Monte Carlo data visible from HepSim. | ||
- | * You want to share your own files, so they will be available from HepSim | + | * to index files so they will be available from HepSim; |
- | * You want to make a mirror | + | * to make mirrors |
Line 17: | Line 19: | ||
====== What do you need ====== | ====== What do you need ====== | ||
- | You need the following: | + | If you decide to publish Monte Carlo files (or make a mirror of the existing files), you need the following: |
* A web server that can hold your data (>1 TB for / | * A web server that can hold your data (>1 TB for / | ||
Line 25: | Line 27: | ||
- | You there is no web server, one can add files to the " | + | You there is no web server, one can add files to the " |
Line 49: | Line 51: | ||
- | wget http:// | + | wget https:// |
tar -zvxf hepsim_web.tgz | tar -zvxf hepsim_web.tgz | ||
cd hepsim_web/ | cd hepsim_web/ | ||
source hs-toolkit/ | source hs-toolkit/ | ||
Line 74: | Line 76: | ||
* copy existing files from the HepSim and put them to the correct directory (will be mirror) | * copy existing files from the HepSim and put them to the correct directory (will be mirror) | ||
- | In both cases, make sure that Linux system administrator set correct permission for the directory " | + | In both cases, make sure that Linux system administrator set the correct permission for the directory " |
If you have indexed the files successfully, | If you have indexed the files successfully, | ||
Line 86: | Line 88: | ||
# now copy a dataset from URL to a new location | # now copy a dataset from URL to a new location | ||
- | SOURCE=http:// | + | SOURCE=https:// |
OUTPUT_DIR=/ | OUTPUT_DIR=/ | ||
hs-mirror -i $SOURCE -o $OUTPUT_DIR | hs-mirror -i $SOURCE -o $OUTPUT_DIR | ||
Line 110: | Line 112: | ||
hs-index events/ | hs-index events/ | ||
Line 126: | Line 128: | ||
====== Using Petrel from Globus====== | ====== Using Petrel from Globus====== | ||
- | Monte Carlo files can be added to the " | + | Monte Carlo files can be added to the " |
- | You will need a "globus" | + | grid [[https:// |
+ | You will need a [[https:// | ||
- | You can run your personal Petrel projects (with enabled https), or you can be added to the existing petrel# | + | You can run your personal Petrel projects (with enabled https) |
- | The directory with Monte Carlo files should be properly indexed as described above, and then you can copy such directory to Petrel. | + | or you can add your files to the existing petrel# |
+ | The directory with Monte Carlo files should be properly indexed as described above, and then you can copy such directory to Petrel | ||
A typical workflow is following: | A typical workflow is following: | ||
Line 144: | Line 146: | ||
* Move the directory with the files to a petrel project (or ask to be included to petrel# | * Move the directory with the files to a petrel project (or ask to be included to petrel# | ||
* Send a URL location of your files to [email protected] | * Send a URL location of your files to [email protected] | ||
Line 154: | Line 152: | ||
When everything is done, this is what you should expect: | When everything is done, this is what you should expect: | ||
- | * You files will be visible on the main HepSim web page and on the current mirrors (takes ~ few days to propagate the changes) | + | * Your files will be visible on the main HepSim web page and on the current mirrors (takes ~ few days to propagate the changes) |
* You can search your files etc. using the main HepSim web page | * You can search your files etc. using the main HepSim web page | ||
* You can search, list and download files using hs-toolkit commands (hs-find, hs-ls, hs-get etc) | * You can search, list and download files using hs-toolkit commands (hs-find, hs-ls, hs-get etc) |
