Differences
hepsim:dev_hepsim [2020/06/26 21:19] hepsim17 |
hepsim:dev_hepsim [2020/06/26 21:24] hepsim17 |
Line 15: | Line 15: | ||
If the dataset is new, you will see a new entry in the HepSim database. Your authorship will be preserved on the HepSim web page. | If the dataset is new, you will see a new entry in the HepSim database. Your authorship will be preserved on the HepSim web page. | ||
If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset. | If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset. | ||
+ | If you created | ||
+ | to HepSim after you index them as explained below. In this case you do not need to maintain | ||
====== What do you need ====== | ====== What do you need ====== | ||
- | You need the following: | + | If you decide to publish Monte Carlo files (or make a mirror of the existing files), you need the following: |
* A web server that can hold your data (>1 TB for / | * A web server that can hold your data (>1 TB for / | ||
Line 54: | Line 57: | ||
tar -zvxf hepsim_web.tgz | tar -zvxf hepsim_web.tgz | ||
cd hepsim_web/ | cd hepsim_web/ | ||
- | wget http:// | + | wget https:// |
source hs-toolkit/ | source hs-toolkit/ | ||
Line 91: | Line 94: | ||
# now copy a dataset from URL to a new location | # now copy a dataset from URL to a new location | ||
- | SOURCE=http:// | + | SOURCE=https:// |
OUTPUT_DIR=/ | OUTPUT_DIR=/ | ||
hs-mirror -i $SOURCE -o $OUTPUT_DIR | hs-mirror -i $SOURCE -o $OUTPUT_DIR |
