Differences
Both sides previous revision Previous revision | Last revision Both sides next revision | ||
hepsim:dev_hepsim [2020/06/26 21:21] hepsim17 |
hepsim:dev_hepsim [2020/06/26 21:22] hepsim17 |
Line 15: | Line 15: | ||
If the dataset is new, you will see a new entry in the HepSim database. Your authorship will be preserved on the HepSim web page. | If the dataset is new, you will see a new entry in the HepSim database. Your authorship will be preserved on the HepSim web page. | ||
If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset. | If you have made a mirror of the existing data, your server will be added as a mirror for a given dataset. | ||
