Differences
hepsim:dev_singularity [2017/10/10 18:49] hepsim17 [Fortran generators] |
hepsim:dev_singularity [2019/10/30 20:59] hepsim17 [Setting up Jas4pp] |
Line 2: | Line 2: | ||
{{indexmenu_n> | {{indexmenu_n> | ||
HepSim software is deployed using a [[http:// | HepSim software is deployed using a [[http:// | ||
Line 11: | Line 12: | ||
- | wget http:// | + | wget http:// |
- | singularity | + | singularity |
After the last line, the HepSim environment software should be ready. The software will be located in the directory given by the environmental variable HEPSIM (/ | After the last line, the HepSim environment software should be ready. The software will be located in the directory given by the environmental variable HEPSIM (/ | ||
Line 22: | Line 23: | ||
docker pull chekanov/ | docker pull chekanov/ | ||
+ | <note important> | ||
The HepSim image is based on a minimalistic version | The HepSim image is based on a minimalistic version | ||
Line 56: | Line 59: | ||
Section [[hepsim: | Section [[hepsim: | ||
+ | ====== Setting up Jas4pp ====== | ||
+ | One can setup a recent Jas4pp (with hs-tools) as | ||
+ | <code bash> | ||
+ | singularity exec centos7hepsim.img | ||
+ | source / | ||
+ | and then type " | ||
+ | All other HepSim commands, such as " | ||
====== HepSim tests ====== | ====== HepSim tests ====== | ||
+ | To setup simulation and reconstruction software from HepSim, you can use this commend: | ||
+ | source / | ||
The docker container has a few basic tests that checks that everything works as expected. | The docker container has a few basic tests that checks that everything works as expected. | ||
Line 89: | Line 114: | ||
This code compiles a Pythia8 program with ProMC output. | This code compiles a Pythia8 program with ProMC output. | ||
You will see several ProMC files inside the directory " | You will see several ProMC files inside the directory " | ||
===== Fast simulation ===== | ===== Fast simulation ===== | ||
Line 113: | Line 139: | ||
./TEST.sh | ./TEST.sh | ||
+ | This example uses the input file " | ||
+ | The final file is output/ | ||
+ | If you make modifications inside " | ||
+ | To do this, run | ||
+ | cd tests/ | ||
More about the full simulations can be found in Sect. [[hepsim: | More about the full simulations can be found in Sect. [[hepsim: | ||
Line 154: | Line 192: | ||
====== Fortran generators ====== | ====== Fortran generators ====== | ||
The previous CentOS7 image is incompatible with older f77-based Monte Carlo generators. | The previous CentOS7 image is incompatible with older f77-based Monte Carlo generators. | ||
- | You can run Fortran Monte Carlo programs (LEPTO, LEPTO/ | + | You can run Fortran Monte Carlo programs (LEPTO, LEPTO/ |
- | This image is based on Scientific-Linux 6.8 and included | + | This image is based on Scientific-Linux 6.8 with the native gcc4.4 with f77 compatibility libraries. The image includes |
- | older libraries. | + | CERNLIB, LHAPDF5.8, HEPMC, CLHEP and other older libraries. |
+ | All Monte Carlo models are interfaced with ProMC IO for compact output of events. | ||
- | singularity exec slc6hepsim.img | + | wget http:// |
+ | singularity exec slc6hepsim.img | ||
+ | Or, if you use Docker: | ||
+ | docker pull chekanov/ | ||
Monte Carlo generators are located inside the directory / | Monte Carlo generators are located inside the directory / | ||
Line 167: | Line 213: | ||
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs: | + | David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs: |
