Differences
hepsim:dev_singularity [2019/10/30 20:40] hepsim17 [HepSim Docker image] |
hepsim:dev_singularity [2019/10/30 20:59] hepsim17 [Setting up Jas4pp] |
Line 24: | Line 24: | ||
- | <note important> | + | <note important> |
The HepSim image is based on a minimalistic version | The HepSim image is based on a minimalistic version | ||
Line 59: | Line 59: | ||
Section [[hepsim: | Section [[hepsim: | ||
+ | ====== Setting up Jas4pp ====== | ||
+ | One can setup a recent Jas4pp (with hs-tools) as | ||
+ | <code bash> | ||
+ | singularity exec centos7hepsim.img | ||
+ | source / | ||
+ | and then type " | ||
+ | All other HepSim commands, such as " | ||
====== HepSim tests ====== | ====== HepSim tests ====== | ||
+ | To setup simulation and reconstruction software from HepSim, you can use this commend: | ||
+ | source / | ||
The docker container has a few basic tests that checks that everything works as expected. | The docker container has a few basic tests that checks that everything works as expected. | ||
Line 92: | Line 114: | ||
This code compiles a Pythia8 program with ProMC output. | This code compiles a Pythia8 program with ProMC output. | ||
You will see several ProMC files inside the directory " | You will see several ProMC files inside the directory " | ||
===== Fast simulation ===== | ===== Fast simulation ===== | ||
Line 116: | Line 139: | ||
./TEST.sh | ./TEST.sh | ||
+ | This example uses the input file " | ||
+ | The final file is output/ | ||
+ | If you make modifications inside " | ||
+ | To do this, run | ||
+ | cd tests/ | ||
More about the full simulations can be found in Sect. [[hepsim: | More about the full simulations can be found in Sect. [[hepsim: | ||
Line 178: | Line 213: | ||
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs: | + | David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs: |
