Differences
Link to this comparison view
Next revision
Previous revision
hepsim:dev_singularity [2019/10/30 20:46]
hepsim17 [Full simulations]
hepsim:dev_singularity [2019/10/30 20:59]
hepsim17 [Setting up Jas4pp]
Line 59: Line 59:
 Section [[hepsim:dev_fpadsim]] explains how to use this image to create full simulations using detector tags. Section [[hepsim:dev_fpadsim]] explains how to use this image to create full simulations using detector tags.
 +====== Setting up Jas4pp ======
 +One can setup a recent Jas4pp (with hs-tools) as
 +<code bash>
 +singularity exec centos7hepsim.img  bash -l
 +source /opt/jas4pp.sh
 +</code>
 +and then type "jaspp". Please forward X11 to see the GUI.
 +All other HepSim commands, such as "hs-ls", "hs-run" should be available.
 ====== HepSim tests ====== ====== HepSim tests ======
 +To setup simulation and reconstruction software from HepSim, you can use this commend:
 +<code bash>
 +source /opt/hepsim.sh
 +</code>
 The docker container has a few basic tests that checks that everything works as expected. The docker container has a few basic tests that checks that everything works as expected.
Line 92: Line 114:
 This code compiles a Pythia8 program with ProMC output. This code compiles a Pythia8 program with ProMC output.
 You will see several ProMC files inside the directory "out". The input for Pythia is given by the control card inside the directory "cards". To recompile the Pythia8 program, type "make". You will see several ProMC files inside the directory "out". The input for Pythia is given by the control card inside the directory "cards". To recompile the Pythia8 program, type "make".
 ===== Fast simulation ===== ===== Fast simulation =====
Line 190: Line 213:
-David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs:eic:singularity|Singularity image for EIC]]. It is based on Arch Linux, and does not contain the usual Linux environment included inside centos7hepsim image.+David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs:eic:singularity|Singularity image for EIC]]. It is based on Arch Linux, and does not contain the usual Linux environment included inside centos7hepsim image.
  --- //[[[email protected]|Sergei Chekanov]] 2017/09/24 17:49//  --- //[[[email protected]|Sergei Chekanov]] 2017/09/24 17:49//
