Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hepsim:dev_singularity [2019/10/30 20:50]
hepsim17 [HepSim Docker image]
hepsim:dev_singularity [2019/10/30 20:55]
hepsim17 [Setting up Jas4pp]
Line 60: Line 60:
 Section [[hepsim:dev_fpadsim]] explains how to use this image to create full simulations using detector tags. Section [[hepsim:dev_fpadsim]] explains how to use this image to create full simulations using detector tags.
-===== Setting up Jas4pp =====+
 +====== Setting up Jas4pp ======
 One can setup a recent Jas4pp (with hs-tools) as One can setup a recent Jas4pp (with hs-tools) as
 <code bash> <code bash>
 +singularity exec centos7hepsim.img  bash -l
 source /opt/jas4pp.sh source /opt/jas4pp.sh
 </code> </code>
Line 74: Line 76:
 ====== HepSim tests ====== ====== HepSim tests ======
 +To setup simulation and reconstruction software from HepSim, you can use this commend:
 +<code bash>
 +source /opt/hepsim.sh
 +</code>
 The docker container has a few basic tests that checks that everything works as expected. The docker container has a few basic tests that checks that everything works as expected.
Line 203: Line 213:
-David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs:eic:singularity|Singularity image for EIC]]. It is based on Arch Linux, and does not contain the usual Linux environment included inside centos7hepsim image.+David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs:eic:singularity|Singularity image for EIC]]. It is based on Arch Linux, and does not contain the usual Linux environment included inside centos7hepsim image.
  --- //[[[email protected]|Sergei Chekanov]] 2017/09/24 17:49//  --- //[[[email protected]|Sergei Chekanov]] 2017/09/24 17:49//
