Differences
hepsim:dev_tags [2017/09/05 19:44] hepsim17 |
hepsim:dev_tags [2017/09/13 21:22] hepsim17 |
Line 4: | Line 4: | ||
====== Submitting tags ====== | ====== Submitting tags ====== | ||
+ | As a HepSim user, you can submit your detector description and the simulation/ | ||
- | ===== Reconstruction tags ===== | + | All detector simulations |
- | + | small (<5 MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags | |
- | Full detector simulations are created using the concept of tags, which are | + | |
- | small (<3MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags | + | |
can be found in [[http:// | can be found in [[http:// | ||
- | In many cases we call them " | + | In many cases we call them " |
A reconstruction tag is associated with the file with the name **rfull[XXX].tgz**, | A reconstruction tag is associated with the file with the name **rfull[XXX].tgz**, | ||
Line 24: | Line 22: | ||
* defining the tag name to be used for downloading events | * defining the tag name to be used for downloading events | ||
* defining the workflow of the simulation-reconstruction steps | * defining the workflow of the simulation-reconstruction steps | ||
- | * creating the necessary files for event visualization using Jas4pp | + | * creating the necessary files for event visualization using Jas4pp |
+ | * feeding the HPC and grid jobs for simulation and reconstruction (for dockers & singularity images). | ||
Reconstruction tags have unique names. There can be several reconstruction tags corresponding to a single detector, since simulation and reconstruction can be done using different software. | Reconstruction tags have unique names. There can be several reconstruction tags corresponding to a single detector, since simulation and reconstruction can be done using different software. | ||
- | They are small files that are sourced by reconstruction software on grid or HPC. A file "rfull[XXX].tgz" | + | They are small files that are sourced by reconstruction software on grid or HPC. A file **rfull[XXX].tgz** |
has everything you need to create LCIO/ROOT files with reconstructed events. | has everything you need to create LCIO/ROOT files with reconstructed events. | ||
+ | ====== Structure of tags ====== | ||
In most cases, the directory inside rfull[XXX].tgz has this structure (for a detector called " | In most cases, the directory inside rfull[XXX].tgz has this structure (for a detector called " | ||
Line 46: | Line 48: | ||
- sifcch7.root | - sifcch7.root | ||
- sifcch7.html | - sifcch7.html | ||
- | - view1.png | + | - view1.png |
- | - view2.png | + | - view2.png |
- some config files | - some config files | ||
Line 59: | Line 61: | ||
<note important> | <note important> | ||
when the tag files are sourced by reconstruction software on each node on HPC or grid, | when the tag files are sourced by reconstruction software on each node on HPC or grid, | ||
- | which are assumed to contain the needed software used in combination with **rfullXXX.tgz** files. | + | which are assumed to contain the needed software used in combination with **rfull[XXX].tgz** files. |
Line 78: | Line 80: | ||
<note tip> | <note tip> | ||
- | A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim | + | A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim. |
Please add **compact.xml** even if it is a dummy file not used for detector description.</ | Please add **compact.xml** even if it is a dummy file not used for detector description.</ | ||
Line 91: | Line 93: | ||
First, request the account [[https:// | First, request the account [[https:// | ||
- | Then, go to [[http:// | + | Then, go to [[http:// |
