Differences
Link to this comparison view
Next revision
Previous revision
hepsim:dev_tags [2017/09/05 19:44]
hepsim17
hepsim:dev_tags [2017/09/13 21:22]
hepsim17
Line 4: Line 4:
 ====== Submitting tags ====== ====== Submitting tags ======
 +As a HepSim user, you can submit your detector description and the simulation/reconstruction chain to HepSim using "tag" files.
-===== Reconstruction tags ===== +All detector simulations in HepSim are created using the concept of tags, which are
- +small (<5 MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags
-Full detector simulations are created using the concept of tags, which are +
-small (<3MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags +
 can be found in [[http://atlaswww.hep.anl.gov/hepsim/recotags.php|this page]].  can be found in [[http://atlaswww.hep.anl.gov/hepsim/recotags.php|this page]].
-In many cases we call them "reconstruction" tags, but, generally, include both Geant4  simulation and reconstruction steps.+In many cases we call them "reconstruction" tags, but, generally, they include Geant4 simulation and reconstruction steps.
 A reconstruction tag is associated with the file with the name **rfull[XXX].tgz**, where **[XXX]** is a number. A reconstruction tag is associated with the file with the name **rfull[XXX].tgz**, where **[XXX]** is a number.
Line 24: Line 22:
   * defining the tag name to be used for downloading events   * defining the tag name to be used for downloading events
   * defining the workflow of the simulation-reconstruction steps   * defining the workflow of the simulation-reconstruction steps
-  * creating the necessary files for event visualization using Jas4pp+  * creating the necessary files for event visualization using Jas4pp (only for slic/lcsim complied software)
 +  * feeding the HPC and grid jobs for simulation and reconstruction (for dockers & singularity images).
 Reconstruction tags have unique names. There can be several reconstruction tags corresponding to a single detector, since simulation and reconstruction can be done using different software.  Reconstruction tags have unique names. There can be several reconstruction tags corresponding to a single detector, since simulation and reconstruction can be done using different software.
-They are small files that are sourced by reconstruction software on grid or HPC. A file "rfull[XXX].tgz"+They are small files that are sourced by reconstruction software on grid or HPC. A file **rfull[XXX].tgz**
 has everything you need to create LCIO/ROOT files with reconstructed events.  has everything you need to create LCIO/ROOT files with reconstructed events.
 +====== Structure of tags ======
 In most cases, the directory inside rfull[XXX].tgz has this structure (for a detector called "sifcch7"): In most cases, the directory inside rfull[XXX].tgz has this structure (for a detector called "sifcch7"):
Line 59: Line 61:
 <note important>Note that the simulation and reconstruction software should not be put inside **rfull[XXX].tgz** files. This file size limit of 5 MB is important to keep a low network bandwidth <note important>Note that the simulation and reconstruction software should not be put inside **rfull[XXX].tgz** files. This file size limit of 5 MB is important to keep a low network bandwidth
 when the tag files are sourced by reconstruction software on each node on HPC or grid,  when the tag files are sourced by reconstruction software on each node on HPC or grid,
-which are assumed to contain the needed software used in combination with **rfullXXX.tgz** files.+which are assumed to contain the needed software used in combination with **rfull[XXX].tgz** files.
 </note> </note>
Line 78: Line 80:
 <note tip> <note tip>
-A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim+A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim.
 Please add **compact.xml** even if it is a dummy file not used for detector description.</note> Please add **compact.xml** even if it is a dummy file not used for detector description.</note>
Line 91: Line 93:
 First, request the account [[https://atlaswww.hep.anl.gov/hepsim/users/selock/user/login.php|HepSim login page]]. First, request the account [[https://atlaswww.hep.anl.gov/hepsim/users/selock/user/login.php|HepSim login page]].
-Then, go to [[http://atlaswww.hep.anl.gov/hepsim/|HepSim]] and look at the yellow menu "Admin info" and then "Tag manager"The use the submit panel to upload the tag file. It does some very basic checks that your tag file has necessary structure, and updates the tag description and the detector page.+Then, go to [[http://atlaswww.hep.anl.gov/hepsim/|HepSim]] and look at the yellow menu "Admin info" and then "Tag manager"Use the submit panel to upload the tag file. HepSim does some basic checks that your tag file has the required structure, and updates the tag description and the detector page.
  --- //[[[email protected]|Sergei Chekanov]] 2017/08/12 21:58//  --- //[[[email protected]|Sergei Chekanov]] 2017/08/12 21:58//
