Differences
Next revision | Previous revision Next revision Both sides next revision | ||
hepsim:dev_truth [2017/02/06 21:09] 127.0.0.1 external edit |
hepsim:dev_truth [2018/08/30 00:54] hepsim17 |
Line 1: | Line 1: | ||
- | [[community: | + | {{indexmenu_n> |
- | ====== Creating | + | [[: |
+ | ====== Creating | ||
+ | HepSim is optimized to keep truth-level in the " | ||
- | HepSim is optimized to keep truth-level in the " | ||
====== Using Pythia8====== | ====== Using Pythia8====== | ||
- | ProMC files can be created directly by Pythia8. Look at the example " | + | Basic examples how to make ProMC and ProIO files from Pythia8 are given in |
+ | [[https:// | ||
+ | ====== Singularity containers====== | ||
+ | Generally, you do not need to install Pythia8 to create ProMC files. You can run Pythia8 using the HepSim singularity container. This topic is described in [[hepsim: | ||
+ | ProMC files can be created directly by Pythia8. Look at the example " | ||
please | please | ||
of Pythia8. If the environmental variable " | of Pythia8. If the environmental variable " | ||
Line 20: | Line 31: | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
+ | * txt2promc | ||
+ | Look at the [[https:// | ||
- | Look at the [[asc: | + | One useful example showing how to read a text file with Monte Carlo events and fill correct |
+ | the example " | ||
====== Using Madgraph5====== | ====== Using Madgraph5====== |
