Differences
hepsim:jas4pp [2017/04/26 18:40] hepsim17 [Examples] |
hepsim:jas4pp [2017/09/25 00:33] hepsim17 |
Line 48: | Line 48: | ||
+ | <note tip>Note that you can also use the [[hepsim: | ||
+ | Jas4pp</ | ||
====== Examples ====== | ====== Examples ====== | ||
Line 110: | Line 111: | ||
- | You can also run Jas4pp in GUI mode. You can process scripts that read PROMC and LCIO files from these HepSim pages: | ||
- | - [[http:// | ||
- | Download any of these scripts, and open it using the " | ||
Line 204: | Line 194: | ||
Also, look at concrete example of how to analyze single particles in [[: | Also, look at concrete example of how to analyze single particles in [[: | ||
+ | ====== Using GUI mode ====== | ||
+ | You can also run Jas4pp in a GUI mode. You can process scripts that read PROMC and LCIO files from these HepSim pages: | ||
+ | - [[http:// | ||
+ | Download any of these scripts, and open it using the " | ||
====== Programming with HepSim ====== | ====== Programming with HepSim ====== | ||
