Differences
hepsim:pgun [2017/02/06 23:05] hepsim17 |
hepsim:pgun [2020/06/19 17:24] hepsim17 |
Line 4: | Line 4: | ||
- | ====== Creating single | + | ====== Creating single |
Single particle samples are created using the ProMC Java package. | Single particle samples are created using the ProMC Java package. | ||
- | Here is an example how to make single particle sample using Jython {{:community: | + | Here is an example how to make single particle sample using Jython {{: |
You can use [[https:// | You can use [[https:// | ||
- | wget --no-check-certificate https:// | ||
fpad particle_gun.py # run this script using Jas4pp | fpad particle_gun.py # run this script using Jas4pp | ||
Line 18: | Line 16: | ||
You can modify this script to change pT, Eta etc. | You can modify this script to change pT, Eta etc. | ||
- | An example implemented in Jython is also given in [[http://jwork.org/dmelt/ | + | An example implemented in Jython is also given in [[https://datamelt.org/ |
