Differences
hepsim:pgun [2017/02/07 02:34] hepsim17 |
hepsim:pgun [2020/06/19 17:25] hepsim17 |
Line 4: | Line 4: | ||
- | ====== Creating single | + | ====== Creating single |
Single particle samples are created using the ProMC Java package. | Single particle samples are created using the ProMC Java package. | ||
Line 16: | Line 16: | ||
You can modify this script to change pT, Eta etc. | You can modify this script to change pT, Eta etc. | ||
- | An example implemented in Jython is also given in [[http://jwork.org/dmelt/ | + | An example implemented in Jython is also given in [[https://datamelt.org/ |
