Differences
hepsim:pgun [2017/02/07 02:45] hepsim17 |
hepsim:pgun [2020/06/19 17:25] hepsim17 |
Line 16: | Line 16: | ||
You can modify this script to change pT, Eta etc. | You can modify this script to change pT, Eta etc. | ||
- | An example implemented in Jython is also given in [[http://jwork.org/dmelt/ | + | An example implemented in Jython is also given in [[https://datamelt.org/ |
