Differences
hepsim:public [2021/09/10 17:11] hepsim17 [Publications] |
hepsim:public [2022/08/12 12:36] hepsim17 [Articles] |
Line 1: | Line 1: | ||
{{indexmenu_n> | {{indexmenu_n> | ||
====== Public results ====== | ====== Public results ====== | ||
- | ======Publications====== | + | ====== |
- | Since 2013, there was a number of publications | + | Since 2013, there was a number of articles |
* A. V. Kotwal, S. Chekanov, M. Low, Double Higgs Production in the 4τ channel from resonances in longitudinal vector boson scattering at a 100 TeV collider, [[http:// | * A. V. Kotwal, S. Chekanov, M. Low, Double Higgs Production in the 4τ channel from resonances in longitudinal vector boson scattering at a 100 TeV collider, [[http:// | ||
Line 47: | Line 49: | ||
* S.V. Chekanov, S. Darmora, W. Islam, C.E.M. Wagner, J. Zhang, Model-independent searches for new physics in multi-body invariant masses, ANL-HEP-166648, | * S.V. Chekanov, S. Darmora, W. Islam, C.E.M. Wagner, J. Zhang, Model-independent searches for new physics in multi-body invariant masses, ANL-HEP-166648, | ||
* Frank E. Taylor, Applications of pT-xR Variables in Describing Inclusive Cross Sections at the LHC. https:// | * Frank E. Taylor, Applications of pT-xR Variables in Describing Inclusive Cross Sections at the LHC. https:// | ||
+ | * S.V.Chekanov, | ||
+ | * S. Darmora et. al, Signal optimization studies for dijet resonances in events with identified leptons using machine learning, June 2021, ATL-COM-PHYS-2021-391, | ||
+ | * S.V. Chekanov, W. Hopkins, Event-based anomaly detection for new physics searches at the LHC using machine learning, https:// | ||
+ | * S.Chekanov et al, " | ||
+ | * B. Nachman et al, Jets and Jet Substructure at Future Colliders, [[https:// | ||
+ | * F. Mokhtar et al., Explaining machine-learned particle-flow reconstruction, | ||
+ | * ATLAS Collaboration, | ||
Line 110: | Line 120: | ||
* S.Chekanov et al., Jas4pp. A Data-Analysis Framework for Physics and Detector Studies. APS April Meeting 2021, https:// | * S.Chekanov et al., Jas4pp. A Data-Analysis Framework for Physics and Detector Studies. APS April Meeting 2021, https:// | ||
* S.Chekanov et. al, Calorimeter performance studies using Monte Carlo simulations for future collider detectors. CPAD Instrumentation Frontier Workshop 2021, 18-22 March 2021, Stony Brook, NY (https:// | * S.Chekanov et. al, Calorimeter performance studies using Monte Carlo simulations for future collider detectors. CPAD Instrumentation Frontier Workshop 2021, 18-22 March 2021, Stony Brook, NY (https:// | ||
+ | * J.Crosby, " | ||
+ | * S.Chekanov, Event-based anomaly detection for new physics searches at the LHC using machine learning, APS April Meeting, Apr 8-14, 2022, https:// | ||
