Differences
hepsim:public [2022/06/06 20:51] hepsim17 [Articles] |
hepsim:public [2022/08/12 12:36] hepsim17 [Articles] |
Line 49: | Line 49: | ||
* S.V. Chekanov, S. Darmora, W. Islam, C.E.M. Wagner, J. Zhang, Model-independent searches for new physics in multi-body invariant masses, ANL-HEP-166648, | * S.V. Chekanov, S. Darmora, W. Islam, C.E.M. Wagner, J. Zhang, Model-independent searches for new physics in multi-body invariant masses, ANL-HEP-166648, | ||
* Frank E. Taylor, Applications of pT-xR Variables in Describing Inclusive Cross Sections at the LHC. https:// | * Frank E. Taylor, Applications of pT-xR Variables in Describing Inclusive Cross Sections at the LHC. https:// | ||
- | * S.V.Chekanov, | + | * S.V.Chekanov, |
* S. Darmora et. al, Signal optimization studies for dijet resonances in events with identified leptons using machine learning, June 2021, ATL-COM-PHYS-2021-391, | * S. Darmora et. al, Signal optimization studies for dijet resonances in events with identified leptons using machine learning, June 2021, ATL-COM-PHYS-2021-391, | ||
* S.V. Chekanov, W. Hopkins, Event-based anomaly detection for new physics searches at the LHC using machine learning, https:// | * S.V. Chekanov, W. Hopkins, Event-based anomaly detection for new physics searches at the LHC using machine learning, https:// | ||
Line 55: | Line 55: | ||
* B. Nachman et al, Jets and Jet Substructure at Future Colliders, [[https:// | * B. Nachman et al, Jets and Jet Substructure at Future Colliders, [[https:// | ||
* F. Mokhtar et al., Explaining machine-learned particle-flow reconstruction, | * F. Mokhtar et al., Explaining machine-learned particle-flow reconstruction, | ||
+ | * ATLAS Collaboration, | ||
