Both sides previous revision
Previous revision
Next revision
Previous revision
Last revision
Both sides next revision
hepsim:quick [2018/08/30 00:50] hepsim17 |
hepsim:quick [2021/05/07 18:30] hepsim17 [Quick start] |
<code bash> | <code bash> |
bash # set bash if you haven't done this before | bash # set bash if you haven't done this before |
wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; | wget https://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz; |
source hs-toolkit/setup.sh | source hs-toolkit/setup.sh |
</code> | </code> |
This creates the directory "hs-toolkit" with HepSim commands. You can also download it as [[http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz | hs-toolkit.tgz]]. Note that | This creates the directory "hs-toolkit" with HepSim commands. You can also download it as [[https://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz | hs-toolkit.tgz]]. Note that |
[[https://www.java.com/en/download/|Java 8]] and above should be installed. | [[https://www.java.com/en/download/|Java 8]] and above should be installed. |
You can view the commands using the bash shell by typing : | You can view the commands using the bash shell by typing : |
<note tip> | <note tip> |
Use [[http://atlaswww.hep.anl.gov/asc/jas4pp | JAS4PP program]] for analysing LCIO | Use [[https://atlaswww.hep.anl.gov/asc/jas4pp | JAS4PP program]] for analysing LCIO |
(*.lcio) files with Geant4 simulations. | (*.lcio) files with Geant4 simulations. |
This program can also be used for truth-level records in the [[https://atlaswww.hep.anl.gov/asc/promc/|PROMC]] or [[ https://github.com/proio-org/| PROIO]] format. | This program can also be used for truth-level records in the [[https://atlaswww.hep.anl.gov/asc/promc/|PROMC]], [[https://github.com/proio-org/| PROIO]] and [[https://root.cern/|ROOT]] file formats. You can also use Delphes/ROOT framework for ROOT files. |
To analyse ROOT files with fast simulations, use Delphes/ROOT framework. | |
</note> | </note> |
Let us show how to find the files associated with a given Monte Carlo event sample. | Let us show how to find the files associated with a given Monte Carlo event sample. |
Go to [[http://atlaswww.hep.anl.gov/hepsim/|HepSim database]] and find the "Files" column. | Go to [[https://atlaswww.hep.anl.gov/hepsim/|HepSim database]] and find the "Files" column. |
It shows URL of truth-level files ("EVGEN"), i.e. files directly created by event generators. | It shows URL of truth-level files ("EVGEN"), i.e. files directly created by event generators. |
Similarly, one can use the download URL: | Similarly, one can use the download URL: |
hs-ls http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5/ | hs-ls https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5/ |
</code> | </code> |
Note that in this approach, one can use URL mirrors close to your geographical location. | Note that in this approach, one can use URL mirrors close to your geographical location. |
The best method to find the needed sample is to use the web page with | The best method to find the needed sample is to use the web page with |
[[http://atlaswww.hep.anl.gov/hepsim/search.php|database search]]. | [[https://atlaswww.hep.anl.gov/hepsim/search.php|database search]]. |
Enter "rfull" in the search field, and you will see all samples with full simulation taggs. Enter "rfast", and you will | Enter "rfull" in the search field, and you will see all samples with full simulation taggs. Enter "rfast", and you will |
* [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull]] list MC after full simulations | * [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull]] list MC after full simulations |
* [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast]] lists MC after fast simulations | * [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast]] lists MC after fast simulations |
* [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=mg5]] - lists all Madgraph5 samples | * [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=mg5]] - lists all Madgraph5 samples |
* [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=higgs%rfast]] - lists Higgs samples after fast simulation | * [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=higgs%rfast]] - lists Higgs samples after fast simulation |
If you prefer to use the command-line approach, you can find URL that corresponds a dataset using this command: | If you prefer to use the command-line approach, you can find URL that corresponds a dataset using this command: |
<code> | <code> |
hs-get http://atlaswww.hep.anl.gov/hepsim/info.php?item=2 data | hs-get https://atlaswww.hep.anl.gov/hepsim/info.php?item=2 data |
</code> | </code> |
<code> | <code> |
hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data | hs-get https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/higgs_ttbar_mg5 data |
</code> | </code> |
All these examples will download all files from the "tev100pp_higgs_ttbar_mg5" event sample. | All these examples will download all files from the "tev100pp_higgs_ttbar_mg5" event sample. |
hs-get tev13pp_higgs_pythia8_ptbins data 3 10 pt100_ | hs-get tev13pp_higgs_pythia8_ptbins data 3 10 pt100_ |
</code> | </code> |
where the name is [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=92|tev13pp_higgs_pythia8_ptbins]]. | where the name is [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=92|tev13pp_higgs_pythia8_ptbins]]. |
The command download files to the "data" directory in 2 threads. The maximum number of download files is 5 and all file names have *pt100* string (i.e. pT>100 GeV). | The command download files to the "data" directory in 2 threads. The maximum number of download files is 5 and all file names have *pt100* string (i.e. pT>100 GeV). |
where "NNN" is a version number. | where "NNN" is a version number. |
You can identify detector geometries that correspond to the tags using [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|detector description page]]. | You can identify detector geometries that correspond to the tags using [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|detector description page]]. |
For example, [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100pp_ttbar_mg5]] | For example, [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=15|tev100pp_ttbar_mg5]] |
sample includes the link "rfast001" (Delphes fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax: | sample includes the link "rfast001" (Delphes fast simulation, version 001). To download the reconstructed events for the reconstruction tag "rfast001", use this syntax: |
As before, one can also download the files using the URL: | As before, one can also download the files using the URL: |
hs-ls http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/rfast001/ # list all files | hs-ls https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/rfast001/ # list all files |
hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/rfast001/ data | hs-get https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/rfast001/ data |
</code> | </code> |
hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc | hs-info https://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc |
</code> | </code> |
<code> | <code> |
hs-info http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc 100 | hs-info https://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc 100 |
</code> | </code> |
hs-view [promc file] | hs-view [promc file] |
</code> | </code> |
This command brings up a GUI window to look at separate events. You should forward X11 to see the GUI. For Windows: download the file [[http://atlaswww.hep.anl.gov/asc/hepsim/hepsim.jar|hepsim.jar]] and click on it. Then open the file as [File]-[Open file]. | This command brings up a GUI window to look at separate events. You should forward X11 to see the GUI. For Windows: download the file [[https://atlaswww.hep.anl.gov/asc/hepsim/hepsim.jar|hepsim.jar]] and click on it. Then open the file as [File]-[Open file]. |
<code> | <code> |
hs-view http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc | hs-view https://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/pythia8_higgs2mumu/tev14_pythia8_h2mm_1.promc |
</code> | </code> |
Here we looked at one file of [[http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/qcd/pythia8/|Pythia8 (QCD) sample]]. | Here we looked at one file of [[http://mc.hep.anl.gov/asc/hepsim/events/pp/14tev/qcd/pythia8/|Pythia8 (QCD) sample]]. |
In this example, we will run a Python (to be more exact, Jython) script and, at the same time, will stream data from the web. | In this example, we will run a Python (to be more exact, Jython) script and, at the same time, will stream data from the web. |
Find a HepSim event sample by clicking the info "Info" column. | Find a HepSim event sample by clicking the info "Info" column. |
For example, look at a ttbar sample from Madgraph: [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|ttbar_mg5]]. | For example, look at a ttbar sample from Madgraph: [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=15|ttbar_mg5]]. |
Find the URL of the analysis script ("ttbar_mg5.py") located at the bottom. Copy it to some foulder. Or use "wget": | Find the URL of the analysis script ("ttbar_mg5.py") located at the bottom. Copy it to some foulder. Or use "wget": |
wget http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/macros/ttbar_mg5.py | wget https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/macros/ttbar_mg5.py |
</code> | </code> |
then we download the analysis script, and then we run this script over the local data using 10000 events: | then we download the analysis script, and then we run this script over the local data using 10000 events: |
<code> | <code> |
hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5 ttbar_mg5 | hs-get https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5 ttbar_mg5 |
hs-run ttbar_mg5 10000 | hs-run ttbar_mg5 10000 |
</code> | </code> |
The above example has some limitations since it uses rather simple editor. | The above example has some limitations since it uses rather simple editor. |
Another approach is to use the full-featured [[http://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] or | Another approach is to use the full-featured [[http://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] or |
[[http://jwork.org/dmelt/|DataMelt]] programs which give more flexibility. | [[https://datamelt.org|DataMelt]] programs which give more flexibility. |
wget -O dmelt.zip http://jwork.org/dmelt/download/current.php; | wget -O dmelt.zip http://jwork.org/dmelt/download/current.php; |
You can also pass URL with data as an argument and limit the calculation to 10000 events: | You can also pass URL with data as an argument and limit the calculation to 10000 events: |
./dmelt/dmelt_batch.sh ttbar_mg5.py http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/ 10000 | ./dmelt/dmelt_batch.sh ttbar_mg5.py https://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_mg5/ 10000 |
</code> | </code> |
As before, use the batch mode using downloaded ProMC files. | As before, use the batch mode using downloaded ProMC files. |
Let assume that we put all ProMC files to the directory "data". Then run [[http://jwork.org/dmelt/|DataMelt]] over the data as: | Let assume that we put all ProMC files to the directory "data". Then run [[https://datamelt.org/|DataMelt]] over the data as: |
<code> | <code> |
./dmelt/dmelt_batch.sh ttbar_mg5.py ttbar_mg5 10000 | ./dmelt/dmelt_batch.sh ttbar_mg5.py ttbar_mg5 10000 |
</code> | </code> |
Then click "run" (or [F8]). | Then click "run" (or [F8]). |
One can also start [[http://jwork.org/dmelt/|DataMelt]] without input files: | One can also start [[https://datamelt.org|DataMelt]] without input files: |
<code> | <code> |
./dmelt/dmelt.sh | ./dmelt/dmelt.sh |
</code> | </code> |
on Linux/Mac. On Windows, run "dmelt.bat" instead. You will see the DatMelt IDE. | on Linux/Mac. On Windows, run "dmelt.bat" instead. You will see the DatMelt IDE. |
Locate an URL location of the analysis script, such as [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=15|ttbar_mg5]] (can be found under "Info" link). Then copy this link using the right mouse button ("Copy URL Location"). | Locate an URL location of the analysis script, such as [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=15|ttbar_mg5]] (can be found under "Info" link). Then copy this link using the right mouse button ("Copy URL Location"). |
Next, in the DMelt menu, go to "File"→"Read script from URL". Copy the URL link of the *.py file to the pop-up DataMelt | Next, in the DMelt menu, go to "File"→"Read script from URL". Copy the URL link of the *.py file to the pop-up DataMelt |
URL dialog and click "run". The program will start reading data from the Web. At the end of the run, you will see a pop-up | URL dialog and click "run". The program will start reading data from the Web. At the end of the run, you will see a pop-up |
There is a simple example showing how to read multiple Monte Carlo files from HepSim, | There is a simple example showing how to read multiple Monte Carlo files from HepSim, |
build anti-KT jets using FastJet, and fill ROOT histograms. Download | build anti-KT jets using FastJet, and fill ROOT histograms. Download |
[[http://atlaswww.hep.anl.gov/asc/hepsim/soft/hepsim-cpp.tgz|hepsim-cpp package]] and compile it: | [[https://atlaswww.hep.anl.gov/asc/hepsim/soft/hepsim-cpp.tgz|hepsim-cpp package]] and compile it: |
<code> | <code> |
about how to read Delphes ROOT files. | about how to read Delphes ROOT files. |
You can find all samples that contain fast simulations using [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast|this link]]. | You can find all samples that contain fast simulations using [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=rfast|this link]]. |
===== Full simulation: LCIO files ===== | ===== Full simulation: LCIO files ===== |
You can find all samples that contain full simulations using [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull|this link]]. | You can find all samples that contain full simulations using [[https://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull|this link]]. |
Durham [[http://durpdg.dur.ac.uk/|HepData]] database maintains "DMelt" scripts compatible | Durham [[http://durpdg.dur.ac.uk/|HepData]] database maintains "DMelt" scripts compatible |
with [[http://atlaswww.hep.anl.gov/hepsim/|HepSim]] analysis scripts, thus it is relatively easy to overlay Monte Carlo predictions and data from published articles. | with [[https://atlaswww.hep.anl.gov/hepsim/|HepSim]] analysis scripts, thus it is relatively easy to overlay Monte Carlo predictions and data from published articles. |
For example, look at the link [[http://durpdg.dur.ac.uk/view/ins1253852|AAD 2013]] from [[http://durpdg.dur.ac.uk/|HepData]] and | For example, look at the link [[http://durpdg.dur.ac.uk/view/ins1253852|AAD 2013]] from [[http://durpdg.dur.ac.uk/|HepData]] and |
download a "DMelt" Jython script with published data. | download a "DMelt" Jython script with published data. |
