Differences
Next revision | Previous revision Last revision Both sides next revision | ||
hepsim:resources [2017/02/07 02:49] hepsim17 created |
hepsim:resources [2018/12/08 00:01] hepsim17 [Acknowledgment] |
Line 1: | Line 1: | ||
+ | {{indexmenu_n> | ||
- | ====== | + | HepSim event data samples are created using: |
+ | * BlueGene/Q supercomputer of the Argonne Leadership Computing Facility ([[https:// | ||
+ | * [[https:// | ||
+ | * ATLAS Connect virtual cluster service (" | ||
+ | * Argonne’s Laboratory Computing Resource Center (LCRC) (" | ||
+ | * ATLAS Analysis support (ASC) cluster at HEP/ANL | ||
+ | The file storage is provided by: | ||
+ | * STASH2 storage at OSG CI Connect | ||
+ | * FAXBOX storage at ATLAS Connect | ||
+ | * MC.HEP server at ASC ANL | ||
+ | * EIC01 server at JLAB | ||
+ | This repository was created following | ||
+ | the guidelines and principles of the | ||
+ | [[http:// | ||
+ | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
- | There is a number of technical tasks that are ideal for scientists who would like to contribute to | ||
- | open-source particle simulations and outreach. | ||
- | HepSim projects can expand your programming | ||
- | data analysis. HepSim uses the same general software and tools as for the ongoing and future experiments. The only difference | ||
- | is that HepSim packages are not proprietorial, | ||
- | to worry about permissions from HEP experiments/ | ||
- | Here are several open tasks: | + | ====== Acknowledgment ====== |
- | * Improve the converter " | ||
- | * The FCC-hh detector has about 300 overlaps in the inner/outer tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT. | ||
- | * Detector and events should be viewed using a Web event browser based on WebGL or other methods. Please look at the [[http:// | ||
- | * Improvements for the graphics of [[https:// | ||
- | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
- | Of course, you can do a lot of your own research, including physics performance studies using truth-level, fast simulations and full simulations. | + | This work is supported |
- | You are only limited | + | Operator of Argonne National Laboratory (``Argonne'' |
+ | Argonne, a U.S. Department | ||
+ | is operated under Contract No. DE-AC02-06CH11357. | ||
+ | This research used resources of the Argonne Leadership Computing Facility at Argonne | ||
+ | National Laboratory, which is supported | ||
- | Please contact hepsim@list.anl if you are interested in these tasks. | + | This research also used resources of the National Energy Research |
+ | Scientific Computing Center, a DOE Office of Science User Facility | ||
+ | supported by the Office of Science of the U.S. Department of Energy | ||
+ | under Contract No. DE-AC02-05CH11231. | ||
