Differences
hepsim:resources [2017/02/07 02:49] hepsim17 |
hepsim:resources [2018/12/08 00:01] hepsim17 [Acknowledgment] |
Line 1: | Line 1: | ||
+ | {{indexmenu_n> | ||
+ | HepSim event data samples are created using: | ||
====== Used resources ====== | ====== Used resources ====== | ||
- | There is a number | + | * BlueGene/Q supercomputer |
- | open-source particle simulations and outreach. Help from undergraduate | + | * [[https:// |
- | HepSim projects can expand your programming | + | |
- | data analysis. HepSim uses the same general software | + | * Argonne’s Laboratory Computing Resource Center (LCRC) (" |
- | is that HepSim packages are not proprietorial, | + | * ATLAS Analysis support (ASC) cluster at HEP/ANL |
- | to worry about permissions from HEP experiments/collaborations to publish your own research. | + | |
+ | The file storage is provided by: | ||
+ | * STASH2 storage at OSG CI Connect | ||
+ | * FAXBOX storage at ATLAS Connect | ||
+ | * [[https:// | ||
+ | * MC.HEP server at ASC ANL | ||
+ | * EIC01 server at JLAB | ||
+ | This repository was created following | ||
+ | the guidelines | ||
+ | [[http://www.energy.gov/ | ||
+ | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
- | Here are several open tasks: | + | ====== Acknowledgment ====== |
- | * Improve the converter " | ||
- | * The FCC-hh detector has about 300 overlaps in the inner/outer tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT. | ||
- | * Detector and events should be viewed using a Web event browser based on WebGL or other methods. Please look at the [[http:// | ||
- | * Improvements for the graphics of [[https:// | ||
- | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
- | Of course, you can do a lot of your own research, including physics performance studies using truth-level, fast simulations and full simulations. | + | This work is supported |
- | You are only limited | + | Operator of Argonne National Laboratory (``Argonne'' |
+ | Argonne, a U.S. Department | ||
+ | is operated under Contract No. DE-AC02-06CH11357. | ||
+ | This research used resources of the Argonne Leadership Computing Facility at Argonne | ||
+ | National Laboratory, which is supported | ||
- | Please contact hepsim@list.anl if you are interested in these tasks. | + | This research also used resources of the National Energy Research |
+ | Scientific Computing Center, a DOE Office of Science User Facility | ||
+ | supported by the Office of Science of the U.S. Department of Energy | ||
+ | under Contract No. DE-AC02-05CH11231. | ||
