Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
Next revision
Both sides next revision
hepsim:usage [2017/03/24 15:16] hepsim17 |
hepsim:usage [2017/04/26 03:30] hepsim17 [Analyzing events] |
* Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual [[https://atlaswww.hep.anl.gov/asc/promc/|ProMC manual]]. If you run over ROOT files from Delphes, use [[https://cp3.irmp.ucl.ac.be/projects/delphes|Delphes manual]]. If you analyse LCIO files with full simulation, look at [[http://lcio.desy.de/v01-07/doc/manual_html/manual.html|LCIO manual]]. | * Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual [[https://atlaswww.hep.anl.gov/asc/promc/|ProMC manual]]. If you run over ROOT files from Delphes, use [[https://cp3.irmp.ucl.ac.be/projects/delphes|Delphes manual]]. If you analyse LCIO files with full simulation, look at [[http://lcio.desy.de/v01-07/doc/manual_html/manual.html|LCIO manual]]. |
Some analysis examples implemented in Python and C++ can be found in [[fcs:fcchh:intro|here]]. Also look for specific topics given below. | Some analysis examples implemented in Python and C++ can be found in [[fcs:fcchh:intro|here]]. Here are more resources: |
| * [[https://github.com/chekanov/HepSim]] - shows examples illustrating how to read ProMC and LCIO files |
| * [[http://atlaswww.hep.anl.gov/hepsim/macrolist.php|ProMC validation]] - lists examples that read ProMC files. The examples are implemented in Jython/Python. They can be converted to Java. |
| * [[http://atlaswww.hep.anl.gov/hepsim/macrolist_lcio.php|LCIO validation]] - lists examples that read LCIO files. The examples are implemented in Jython/Python. They can be converted to Java. |
====== Finding detector simulations ====== | ====== Finding detector simulations ====== |
