Next revision
Previous revision
Last revision
Both sides next revision
hepsim:usage_detectors [2017/02/06 21:16] 127.0.0.1 external edit |
hepsim:usage_detectors [2017/04/03 03:04] hepsim17 |
[[hepsim:|<< back to HepSim manual]] | {{indexmenu_n>7}} |
| [[:|<< back to HepSim manual]] |
====== Detector description and reconstructed tags ====== | |
| ====== Detector descriptions ====== |
Here we describe available reconstruction tags used by HepSim. | Here we describe available reconstruction tags used by HepSim. |
| All detectors can be found in [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|Detector description page]]. |
| Data are reconstructed using the so-called reconstruction tags, which can have either "rfastXXX" or "rfullXXX" name, where XXX is a number. Each tag was reconstructed with certain detector plus some optional parameters for simulation and reconstruction |
====== Fast simulations ====== | ====== Fast simulations ====== |
The file format is ROOT. | The file format is ROOT. |
Look at [[community:hepsim:usage_fast|this description]]. | Look at [[:hepsim:usage_fast|this description]]. |
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== |
Full simulations use SLIC software. | Full simulations use the SLIC software. The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|here]]. |
The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|here]]. | |
Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as | Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as |
^ Tag name ^ Detector description ^ Documentation / GEO files ^ Available data ^ View ^ | ^ Tag name ^ Detector description ^ Documentation / GEO files ^ Available data ^ View ^ |
| rfull001 | Original SiD detector, E(CM)=1 TeV (e+e-) (sidloi3). [[http://mc.hep.anl.gov/asc/hepsim/events/mumu/10tev/mm10tev_pythia6_zprime10tev_ww/rfull001/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.heprep|sidloi3.heprep]] [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.gdml.gz|sidloi3.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull001| find=rfull001]] | {{:community:hepsim:sid.png?200|SiD}} | | | rfull001 | Original SiD detector, E(CM)=1 TeV (e+e-) (sidloi3). [[http://mc.hep.anl.gov/asc/hepsim/events/mumu/10tev/mm10tev_pythia6_zprime10tev_ww/rfull001/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.heprep|sidloi3.heprep]] [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidloi3/sidloi3.gdml.gz|sidloi3.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull001| find=rfull001]] | {{:hepsim:sid.png?200|SiD}} | |
| rfull002 | CEPC detector, E(CM)=250 GeV (e+e-) (sidcc1) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull002/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.heprep|sidcc1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.gdml.gz|sidcc1.gdml.gz]], | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull002| find=rfull002]] | {{:community:hepsim:sicpec.png?200| CEPC}} | | | rfull002 | CEPC detector, E(CM)=250 GeV (e+e-) (sidcc1) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull002/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.heprep|sidcc1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc1/sidcc1.gdml.gz|sidcc1.gdml.gz]], | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull002| find=rfull002]] | {{:hepsim:sicpec.png?200| CEPC}} | |
| rfull101 | CEPC detector, E(CM)=250 GeV (e+e-) (sidcc2) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull101/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.heprep|sidcc2.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.gdml.gz|sidcc2.gdml.gz]], | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull101| find=rfull101]] | {{:community:hepsim:sicpec.png?200| CEPC}} | | | rfull101 | CEPC detector, E(CM)=250 GeV (e+e-) (sidcc2) [[http://arxiv.org/abs/1604.01994|arxiv:1604.01994]], [[http://mc.hep.anl.gov/asc/hepsim/events/ee/250gev/pythia6_zpole_ee/rfull101/info.txt|info]] | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.heprep|sidcc2.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sidcc2/sidcc2.gdml.gz|sidcc2.gdml.gz]], | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull101| find=rfull101]] | {{:hepsim:sicpec.png?200| CEPC}} | |
| rfull051 | SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic1) (development) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.heprep|sieic1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.gdml.gz|sieic1.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull051| find=rfull051]] | {{:community:hepsim:sieic.png?200|EIC}} | | | rfull051 | SiEIC1 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic1) (development) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.heprep|sieic1.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic1.gdml.gz|sieic1.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull051| find=rfull051]] | {{:hepsim:sieic.png?200|EIC}} | |
| rfull052 | SiEIC2 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic2) (development) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic2/sieic2.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic2.heprep|sieic2.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic2/sieic2.gdml.gz|sieic2.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull052| find=rfull052]] | {{:community:hepsim:sieic.png?200|EIC}} | | | rfull052 | SiEIC2 detector for EIC, E(CM) < 141 GeV (ep, eN) (sieic2) (development) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic2/sieic2.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic1/sieic2.heprep|sieic2.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sieic2/sieic2.gdml.gz|sieic2.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull052| find=rfull052]] | {{:hepsim:sieic.png?200|EIC}} | |
| rfull006 | SiFFC-v4 for FCC-hh (pp, E(CM)=100 TeV) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.heprep|sifcch4.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.gdml.gz|sifcch4.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006| find=rfull006]] | {{:community:hepsim:sifcc.png?200|SiFCC}} | | | rfull006 | SiFFC-v4 for FCC-hh (pp, E(CM)=100 TeV) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.heprep|sifcch4.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.gdml.gz|sifcch4.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006| find=rfull006]] | {{:hepsim:sifcc.png?200|SiFCC}} | |
| rfull007 | SiFFC-v5. (pp, 100 TeV) As SiFCC-v4 but with x4 larger HCAL cells | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.heprep|sifcch5.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.gdml.gz|sifcch5.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull007| find=rfull007]] | {{:community:hepsim:sifcc.png?200|SiFCC-v4}} | | | rfull007 | SiFFC-v5. (pp, 100 TeV) As SiFCC-v4 but with x4 larger HCAL cells | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.heprep|sifcch5.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch5/sifcch5.gdml.gz|sifcch5.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull007| find=rfull007]] | {{:hepsim:sifcc.png?200|SiFCC-v4}} | |
| rfull009 | SiFFC-v7 (pp, 100 TeV) As SiFCC-v4 but with improved tracker (corrected infrastructure support for inner and outer tracker, reduced gaps between silicon modules) and Fast Pandora clustering. Aug 17, 2016 | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.heprep|sifcch7.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.gdml.gz|sifcch7.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull009| find=rfull009]] | {{:community:hepsim:sifcc7.png?200|SiFCC-v7}} | | | rfull009 | SiFFC-v7 (pp, 100 TeV) As SiFCC-v4 but with improved tracker (corrected infrastructure support for inner and outer tracker, reduced gaps between silicon modules) and Fast Pandora clustering. Aug 17, 2016 | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.heprep|sifcch7.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch7/sifcch7.gdml.gz|sifcch7.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull009| find=rfull009]] | {{:hepsim:sifcc7.png?200|SiFCC-v7}} | |
| rfull010 | Same as SiFFC-v7, but HCAL cells are 20x20cm (vs 5x5 cm) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.heprep|sifcch8.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.gdml.gz|sifcch8.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull010| find=rfull010]] | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull010 | Same as SiFFC-v7, but HCAL cells are 20x20cm (vs 5x5 cm) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.heprep|sifcch8.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch8.gdml.gz|sifcch8.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull010| find=rfull010]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull011 | Same as SiFFC-v7, but fine HCAL cells. HCAL cell size is 2x2cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.heprep|sifcch9.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch9.gdml.gz|sifcch9.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull011| find=rfull011]] | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull011 | Same as SiFFC-v7, but fine HCAL cells. HCAL cell size is 2x2cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch9/sifcch9.heprep|sifcch9.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch8/sifcch9.gdml.gz|sifcch9.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull011| find=rfull011]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:community:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| | rfull014 | Same as SiFFC-v7, but relaxed hit cuts for HCAL and ECAL | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.heprep|sifcch12.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch12.gdml.gz|sifcch12.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull014| find=rfull014]] | {{:hepsim:sifcc7.png?200|SiFCC-v12}} | |
The output file format is LCIO. The files can be read as explained [[community:hepsim:usage_full|here]]. To view geometries using | The output file format is LCIO. The files can be read as explained [[:hepsim:usage_full|here]]. To view geometries using |
ROOT geometry package, run these commands: | ROOT geometry package, run these commands: |
