Differences
Link to this comparison view
Next revision
Previous revision
hepsim:usage_detectors [2017/02/06 23:51]
hepsim17
hepsim:usage_detectors [2017/04/03 03:06]
hepsim17
Line 4: Line 4:
-====== Detector description and reconstructed tags ======+====== Detector descriptions ======
 Here we describe available reconstruction tags used by HepSim. Here we describe available reconstruction tags used by HepSim.
 +All detectors can be found in [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|Detector description page]].
 +Data are reconstructed using the so-called reconstruction tags, which can have either "**rfastXXX**" (fast simulations) or "**rfullXXX**" (full simulation and reconstruction) name, where XXX is a number. Each tag is reconstructed with certain detector plus some optional parameters for simulation and reconstruction.
 +You can find detectors that correspond to a given tag using [[http://atlaswww.hep.anl.gov/hepsim/recotags.php|RecoTag page]].
 ====== Fast simulations ====== ====== Fast simulations ======
Line 25: Line 32:
-Full simulations use SLIC software.  +Full simulations use the SLIC software.  The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/detectors.php|here]].
-The geometry files with full detector descriptions are [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|here]].+
 Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as Each tag corresponds to a certain detector, and other way around. You can find the detector name using a tag as
Line 65: Line 71:
 | rfull012    |  Same as  SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]]        | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | rfull012    |  Same as  SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]]        | {{:hepsim:sifcc7.png?200|SiFCC-v8}} |
 | rfull013    |  Same as  SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]]        | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | rfull013    |  Same as  SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7)    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]]        | {{:hepsim:sifcc7.png?200|SiFCC-v8}} |
 +| rfull014    |  Same as  SiFFC-v7, but relaxed hit cuts for HCAL and ECAL    [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.html|description]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.heprep|sifcch12.heprep]],  [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch12.gdml.gz|sifcch12.gdml.gz]]        |   [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull014| find=rfull014]]        | {{:hepsim:sifcc7.png?200|SiFCC-v12}} |
-The output file format is LCIO. The files can be read as explained [[community:hepsim:usage_full|here]]. To view geometries using +The output file format is LCIO. The files can be read as explained [[:hepsim:usage_full|here]]. To view geometries using
 ROOT geometry package, run these commands: ROOT geometry package, run these commands:
